Rhino ST6 CNC Lathe Restoration
Results 1 to 4 of 4
Thread: Rhino ST6 CNC Lathe Restoration
    Member bgriggs's Avatar
    Aug 2003
    Syracuse
    Default Rhino ST6 CNC Lathe Restoration
    Rhino ST6 CNC Lathe Restoration-2021-06-04-21-10-56-jpg
    I recently bought a Rhino ST6 CNC Lathe from a Craigslist ad. The lathe is is OK shape but has a rusty cabinet. I did some research and it looks like these lathes were made in the 1990s for Schools.
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
    Aug 2003
    Syracuse
    Default Re: Rhino ST6 CNC Lathe Restoration
    Rhino ST6 CNC Lathe Restoration-2021-06-04-21-11-07-jpg
    This is a slantbed lathe. It has a maximum turning size of 2".
    Aug 2003
    Syracuse
    Rhino ST6 CNC Lathe Restoration-2021-06-04-21-11-34-jpg
    The original electronics used a DOS based PC. I intend to change all the electronics out for newer equipment. The Centroid Acorn and some Hybrid Steppers.
    Aug 2003
    Syracuse
    Rhino ST6 CNC Lathe Restoration-2021-06-04-21-11-42-jpg
    The Spindle motor is a Baldor 90VDC 1/2HP motor.
    Anyone have any suggestions for how to remove the old paint and rust?
