If you do direct drive then the holding torque on the stepper would limit the type of work you can do. The gearboxes multiply the holding torque so you can do machining away from the axis of rotation without fear of loosing steps. Most of the time the slow RPMs due to the gear reduction aren't a deterrent to this implementation. Backlash is always an issue with gear reduction on 4th axis.
doing a word search in these forums can yield a wealth of information quickly.
