Need Help! LMS 3990 110V to 220V
Results 1 to 4 of 4
Thread: LMS 3990 110V to 220V
    Nov 2006
    Default LMS 3990 110V to 220V
    is there a way to configure the controller to work on 220V if it's originally made for 110V?
    Dec 2013
    Default Re: LMS 3990 110V to 220V
    Transformer maybe?
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    120/240 60Hz in N.A. now.
    If using an isolation transformer, one side of the secondary has to be referenced to the service Earth GND conductor, this then also becomes the neutral.
    Nov 2006
    Thank you Jim and Al. Yes, I use it with a transformer already for some time and it is OK.
