Stepper Amperage
Results 1 to 5 of 5
Thread: Stepper Amperage
    Nov 2015
    Default Stepper Amperage
    I am retrofitting a mill and the old steppers just aren't working well on all three axis so I am replacing them and the drivers as well. I am planning on keeping the power supply, but I want to make sure I don't get to high Amperage steppers.
    The power supply is a 48volt toroidal power supply. It has wires running to each stepper and each of those three circuits has a 2 Amp Fuse on it. Does that mean I can use the 2/3 rule and use 3 Amps steppers? Or am I limited to 2 Amp steppers, because of the fuses?
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Stepper Amperage
    If you get "higher" amperage steppers they will work, just at the set amperage of the driver. Maybe the steppers are fine and you need to adjust the driver settings or the controller settings (or its a mechanical issue with the machine. tight bearings, alignment etc). I'd work through the system before replacing anything and track down the exact cause of the issue. What do you mean by "not working well" steppers either work or don't work? usually.. Peter
    Mar 2003
    Shelby Township
    What's the current rating on the power supply?
    I'd get rid of the fuses, and get 5 or 6 amp steppers. Typically, the higher the current, the better the performance. 2-3 amp steppers are on the lower end for power and speed.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Member TomKerekes's Avatar
    May 2006
    Note that the average current from a supply is usually much lower than the stepper current. For example a 2.4V 5A motor will only draw about 0.25A from a 48V supply when stopped due to conservation of energy. Both are 12Watts. As the motor moves under load the motor will provide mechanical power and draw more current from the supply.
    Regards
    TK http://dynomotion.com
    Nov 2015
    Its definitely the steppers that are bad. When I test it the X axis works fine. The Z axis didn't move at all I removed the stepper and it was spinning only intermittently when I test it. The Y axis works fine going down but going up it skips and makes noise. All three of the drivers seem to be working though since I tested them on the X axis.
    The transformer is made by Talema its about 110mm x 60mm I cant find the model number on their site and it doesn't have any specification other then that on the side. It might be similar to one of these.
    https://talema.com/wp-content/upload...ary-0225VA.pdf
    https://talema.com/wp-content/upload...ary-0300VA.pdf
    Attachment 451443Attachment 451445Attachment 451447Attachment 451449
    The mill is a LabVolt 5600. The capacitor is a mallory.
Stepper Amperage
Stepper Amperage
Stepper Amperage
