looks good. I really like your re-use of the existing saddle piece with the "leveling plate". Pretty clever right there.
I have just finished my conversion on a Optimum MH-28V fitted with
Nemo 34 stepper motors, 20mm linear rails with Hiwin Linear bearings, 20mm ball screws, coolant tank and enclosure shown in the photos attached.
- Standard linear motion conversion to linear rails.
- Build Thread- G0704 CNC Conversion - Linear Rails, Servos, Ballscrews
- Need Help!- DIY making my own linear rails from 20mm steel what should i use as a protective coat
- Small chinese lathe ways, or linear rails for cnc conversion, accuracy difference?
- 16mm vs. 20mm supported linear rails...
