Re: Your experience using closed loop steppers on Sieg X2?
well I certainly don't use them on an X2, but I have been using closed loop steppers on my RF45 for many years now.
Pros:
- no tuning, plug them in and they work
- positioning error alarms. I have mine wired so that if any steps are lost on any axis it throws an estop and will likely save your part from being ruined. It's saved me a few times.
cons:
- a little pricey and dated verses some of the AC or DC servos available today.
- position feedback comes off the motor itself and will not account for backlash in your system.
overall, they are significantly better than regular steppers, but if you have the money i'd go right to some clearpath or DMM motors.
Mine are remote drivers. They were the only kind available when I bought them.
I wouldn't expect to see any increase in accuracy, they have the same number of steps/rev as regular steppers, but you will be able to know when you've lost steps.
as far as specs, the motor torque and speed will be exactly the same as a similarly rated open-loop stepper.
CS900 did not say anything about the difference between separate (remote) drivers and drivers attached to the steppers. (CS900 said the only ones available when they bought were the separate drivers).
I would expect all closed loop steppers to have a fault output to signal to the controller when steps have been lost.
