G0704 Motor doesn't turn on NEED HELP
Results 1 to 4 of 4
Thread: G0704 Motor doesn't turn on NEED HELP
    Member Blakeo44's Avatar
    Mar 2020
    Default G0704 Motor doesn't turn on NEED HELP
    When I turn on the machine the spindle speed indicator reads 0 and when I turn the spindle speed adjustment knob nothing happens. Note, I have taken off the safety guard and hard wired the switch to permanently stay on. The spindle turns freely by hand with no noticable issues and displays the spindle speed when doing so. Both fuses on the back are good. The mill hasn't been used for any heavy duty use. Any help is greatly appreciated!!!
    Member arizonavideo's Avatar
    May 2008
    Default Re: G0704 Motor doesn't turn on NEED HELP
    You need to close the splash gard...
    youtube videos of the G0704 under the name arizonavideo99
    Jan 2018
    United Kingdom
    Quote Originally Posted by Blakeo44 View Post
    Must be an issue with your wring. If you spliced it it might be in the 'guard open' position.
    Mar 2020
    Quote Originally Posted by dazp1976 View Post
    When the guard is open, the switch disengages power so I just hard wired it close. Has never been a problem since doing it. Has to be something else. Following the wiring diagram I can't find anything out of the ordinary either.
