From everything I read the enable pins dont have to be used. If you do use them, there is an extra layer of protection. How to wire the enable pin on a stepper drive?
My driver has Pul+,Pul-,Dir+,Dir-,Ena+,Ena-, i'm using C11G board, my concern is the wiring diagram doesn't use Ena+,Ena- there diagram uses c10 board for example. If It make any difference I'm running closed loop steppers https://www.cnc4pc.com/pub/media/pro...es/WS_89_1.pdf
A lazy man does it twice.
