Need Help! wiring power to a driver?
Results 1 to 14 of 14
Thread: wiring power to a driver?
    Jan 2012
    Default wiring power to a driver?
    I've begun to wire my steppers I'm stuck , To connect power my driver it has AC1 & AC2 is one POS. and one NEG.?
    wiring power to a driver?-20200214_124938-jpg
    Mar 2003
    Shelby Township
    Default Re: wiring power to a driver?
    AC power does not use positive and negative.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Jan 2012
    I have 60volt switching power supply has POS and NEG. outputs
    Member peteeng's Avatar
    Jul 2018
    dum dum
    RM - but a SMPS puts out DC you need an AC output. You need a 20-80V AC power source. Put up an image of the output of the SMPS....Peter
    Mar 2003
    Shelby Township
    Yes, you have a DC power supply, and a drive that requires AC power.
    Member CitizenOfDreams's Avatar
    Nov 2012
    A DC power supply (30 to 110VDC) will work too, according to the manual. As long as it has enough power.
  7. #7
    Jan 2012
    here is my power supply wiring power to a driver?-20200214_143159-jpg
  8. #8
    Jan 2012
    citizen dream you say it don't matter ac or dc ? does it matter which way i hook it up?
  9. #9
    Jul 2018
    dum dum
    COD - Can you show image of where in manual it says DC is OK? Why do they say AC when they could have said AC/DC??? Found it but does seem odd.... Peter
    it mentions it in 3 places but does not say which polarity to use so maybe does not matter???
    Attached Thumbnails Attached Thumbnails wiring power to a driver?-ac-dc-jpg
  10. #10
    Nov 2012
    Polarity does not matter. Input power goes to a diode bridge inside the servo, so you can connect "+" and "-" whichever way you like.
  11. #11
    Jan 2012
    CitizenOfDreams Thanks! i will give it a go
  12. #12
    Jan 2018
    United Kingdom
    I'd buy a toroidal AC supply. Something like a dual output 40v unit and wire it in series to output 80v AC.
    A 60v DC might be a dissapointment.
    Such as:
    https://uk.farnell.com/multicomp/vtx...40v/dp/1675097
    Or for a powerful system:
    https://uk.farnell.com/multicomp/vtx...40v/dp/1675107
    https://electro-dan.co.uk/electronics/wiringtrans.aspx
  13. #13
    Feb 2008
    United Kingdom
    As no one else has mentioned it - that is a SERVO driver and you have said you are using STEPPERS with encoders elsewhere ? ? ? Servos maybe AC powered - steppers are most certainly DC powered and polarity connections will be important yo ensure rotation direction is as commanded and not reversed!
  14. #14
    Nov 2012
    Quote Originally Posted by kawazuki View Post
    We are talking about the power supply connection, not the motor connection. AC/DC power has nothing to do with the motor type, it depends on whether the driver has a built-in rectifier. This particular one does, so it can be powered with either AC or DC.
