CNC Red Cam Help
Results 1 to 5 of 5
Thread: CNC Red Cam Help
    Member TireSlayer's Avatar
    Jan 2020
    Default CNC Red Cam Help
    Hello,
    I recently purchased a used Red Cam CNC benchtop machine and I’m having troubles getting it going. I am using Mach 3 on my laptop for now just to get everything moving. I feel like my problem is in the ports and pins configuration. Pins 2 and 3 are not illuminating which I’m told is my main problem, nothing will work until they are working.
    I have port 1 enabled, motor outputs I have X pin 2/3, Y pin 3/4 and Z pin 5/6. Output signals I have charge pump enabled 1/17.
    Can’t really figure out what else I need, any information is greatly appreciated.
    Attached Thumbnails Attached Thumbnails CNC Red Cam Help-c64a653d-10ac-486d-b546-544d4e7e0963-jpg   CNC Red Cam Help-8f9fdba7-6d4f-4d47-8d3f-78d84542ef56-jpg
    Dec 2005
    madagascar
    Default Re: CNC Red Cam Help
    First off check that a laptop is OK. A while ago is was conventional wisdom that the parallel port on a laptop was not OK. It had to be a fullsize PC. I may be out of date though.
    Jan 2020
    Hmm interesting. When I do plug in my laptop it does successfully download the driver. But one thing that is odd is I can't get the Reset to flash in Mach 3 when pressing the E-stop button on my mill which tells me the laptop and mill are not connecting. Any suggestions on how I can confirm this? Thanks
    Dec 2005
    madagascar
    Sorry, I can't give more details, I don't have. It was something about the amount power the parallel port of laptops not being sufficient to drive the electronics, I could be wrong though.
    Either try a demo version of mach3 on a fullsize PC or head on over to the Mach3 forum?
    Jan 2018
    United Kingdom
    Desktop pc's with parallel port for that type board (DB25 parallel connector).
    Laptops for usb and lan boards.
    Get a cheap desktop or get a new usb or lan board.
CNC Red Cam Help
CNC Red Cam Help
CNC Red Cam Help
