Backplate adapter for 4" chuck
Results 1 to 5 of 5
Thread: Backplate adapter for 4" chuck
    Member crazybrit's Avatar
    Apr 2011
    Default Backplate adapter for 4" chuck
    My cnc lathe was originally equipped with a 4" chuck and a separate 2-1/4"-8 threaded backplate adapter.
    Unfortunately the chuck was missing when I got the lathe so I need to purchase a replacement.
    My question is whether I need to machine my own backplate adapter using something like this (I can't find one specific to a 4", this is smallest I've found) https://littlemachineshop.com/produc...ProductID=1923
    Or whether I will get sufficient accuracy with a pre made one such as this (https://allindustrial.com/all-indust...-lathe-chucks/) which seems to match the chuck I'm looking at.
    If anyone knows of alternatives I'd love to get a URL.
    Sent from my MI PAD 4 PLUS using Tapatalk
    Member Fastest1's Avatar
    Nov 2009
    Default Re: Backplate adapter for 4" chuck
    Both routes would be ok depending on your skill level. I would think you could skim cut the prebuilt one on your lathe to correct most issues.
    A lazy man does it twice.
    Apr 2011
    Quote Originally Posted by Fastest1 View Post
    That's what I was hoping. The prebuilt is cheaper and I have so many projects already that I'm looking to simply things.
    Nov 2009
    There is no shame in getting it done quickly ;-)
    Mar 2017
    Go with the finished one. Either way, you should install it and then check the runout and concentricity. If it isn't perfect give it a skim cut as fastest1 said. You should also then check the runout of the chuck after it is on the plate and true it up.
