Need Help! motion control board (breakout board ) which one to buy?? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Thread: motion control board (breakout board ) which one to buy??
  1. #21
    Dec 2005
    madagascar
    Default Re: motion control board (breakout board ) which one to buy??
    @ger21, any suggestions on software? Care to share your top two or three software? ( based on your previous comment a software that uses Ethernet is prefered?)
  2. #22
    Mar 2003
    Shelby Township
    I'm using UCCNC. A lot of former Mach3 users have moved to it, and find it a much better product. New features are constantly being added.
    Many like the Centroid Acorn, claiming it's a more "industrial" solution.
    LinuxCNC is good, if you don't like Windows.
    There are other options, some more expensive, some cheaper.
    At the end of the day, it's a matter of personal preference. Does it do what you want and need it to do. Some may meet your needs, others may not.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  3. #23
    Jan 2012
    control software if possible i would like to be able to have a choice of running Mach 3 , Linux cnc , or Uccnc
    like to machine 3D so all 3 axis moving same time
    have any recommendations?
  4. #24
    Jan 2011
    Personally if I were building another machine I would use UCCNC, thru the UC300ETH-5LPT To The Gecko540. Simple and proven system with good support
  5. #25
    Mar 2011
    Quote Originally Posted by ericks View Post
    Well, i spoke too soon. The axbb-e is not working exactly as their specs say
    Hello. I am interested in the AXBB-E as well. Can you elaborate on the problems you are having? Thank you.
    Don
  6. #26
    Jun 2015
    Sweden
    Quote Originally Posted by spaceman7 View Post
    Don
    He already wrote in another forum topic that his problem is that the analog 0-10V output on his AXBB controller does not go up to 10Volts, just to 9.2 Volts is what he wrote if I recall.
    On my AXBB it goes up to 9.9Volts.
  7. #27
    Member ericks's Avatar
    Sep 2019
    Don
    Yes, not going all the way up to 10. Not a big deal cause i just scale my drive analog input accordingly. My biggest problem with this board is/was the lack of 0V5 points for the stepper signal wiring. Also the jumper position was opposite to what is indicated in their manual. For the price it's a good deal still
  8. #28
    Mar 2011
    Quote Originally Posted by OlfCNC View Post
    Thank you for replying... I did not catch that in the other topic. Good to hear yours is almost 10V. I'm coming from a C-10 BOB (using parallel port) and Leadshine drivers w/Mach 3 and now exploring both acorn and uucnc.
  9. #29
    Mar 2011
    Thank you for the information. I'm really leaning toward this, and I don't think it will be a deal breaker for me. Definitely looks like a solid setup.
    Don
  10. #30
    Sep 2019
    Don
    Easy to set up too
  11. #31
    Sep 2019
    Don
    Here is a little look inside the AXBB-E. Took this when i had to remove the jumper for 0-10V....which i later had to replace
    Attached Thumbnails Attached Thumbnails motion control board (breakout board ) which one to buy??-axbb-e1-jpg
  12. #32
    Jan 2012
    i been looking at Acorn CNC Controller for $299 i don't like the i deal on there cnc 12 program is Limited to 50Kb G-code file size and if you want more add $139 w/ Centroid Pro software , is there a better alternative /any recommendations?
  13. #33
    Member Dutch-Bikes's Avatar
    Aug 2019
    Quote Originally Posted by rmachinist View Post
    I went with the Acorn and really happy with it! I did go basic for awhile, was good enough to get up and running to learn everything (other than operating a waterjet I have no cnc backround). Loading each opp gets old by the time you want to start making parts though haha! Getting pro after setting up and learning it helps brake the cost up.
  14. #34
    Mar 2003
    Shelby Township
    Everyone will tell you that their personal preference is "better". Only someone that's used multiple controllers extensively can actually tell you which is truly "better".
    And "Better" may come down to what features one may need or use. So one might be considered better because it has specific features that another controller does not.
    When considering the Acorn, don't think of the Pro software as an additional cost, as it's really just part of the overall cost.
    I'm using UCCNC with a UC300ETH and UB-1. Cost is similar to the Acorn and Pro software. You can get the cost much lower with their cheaper controllers and cheap breakout boards.
    Mach4 with an ESS and breakout boards cost a bout the same as Acorn and Pro software.
    Eding CNC with their higher end control boards costs more than Acorn and Pro software.
    If to you, "Better" means cheaper, than look at LinuxCNC.
