PM-30MV with BT30 Spindle?
Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: PM-30MV with BT30 Spindle?
    Oct 2005
    Default PM-30MV with BT30 Spindle?
    I have a PM-30MV on order, and I'm considering possibly upgrading the headstock/spindle assembly from R8 to BT30.
    The thought is to replace the spindle with a Chinese BT30 belt-driven spindle to get 6000/8000/10000 RPM, and combine it with a 1.5kw/2.2kw AC servo spindle.
    The headstock would be replaced with an assembly made of 3/4" steel plates and 3/4" wall steel tube, with 1" steel plate for the back plate to attach to the Z axis dovetail block.
    And eventually, to add one of these BT30 ATC assemblies.
    PM-30MV with BT30 Spindle?-pm-30mvl-assembly-v11-png
    PM-30MV with BT30 Spindle?-bt30-head-v13-jpg
    PM-30MV with BT30 Spindle?-bt30-spindle-png
    PM-30MV with BT30 Spindle?-1-5kw-servo-spindle-png
    PM-30MV with BT30 Spindle?-bt30-atc-png
    Would this kind of spindle and motor be too much for the PM-30MV?
    Keep in mind, it already has a 3000 RPM spindle and a 1.5KW brushless motor.
    Sanity check requested.
    Dec 2005
    madagascar
    Default Re: PM-30MV with BT30 Spindle?
    As far as spindle power goes, it depends on what you will be cutting, although more power is always nice, more weight on the head isn't. Especially with your spindle adapter idea.
    Your plan to build-up the spindle has too many risks: rigidity, cracked welds and warping over time.
    If you must build it up rather than start with a solid block, then the shape you came up with is springy in the +/- X direction, the box needs to be closed in the front and the round tube needs to protrude though the top and bottom plate in order to get proper welds. The entire assembly should be normalized before machining to size. But in the end don't weld it up.
    The BT30 and the rest of the machine can work very hard, your spindle idea will by far be the weakest part of the machine..
    Oct 2005
    Quote Originally Posted by cncuser1 View Post
    Welding 3/4" and 1" plate is probably out of the question, I don't have a welder (yet).
    I was originally thinking that the plates would be mechanically joined, bolted together steel plates.
    I could also do the same with cast iron plates, bolted together.
    However, as you mentioned machining the entire head out of a block of gray cast iron is also a possibility.
    The cast iron head would still need to be bolted to the Z block.
    Plans for cutting would be mostly aluminum, hence the desired higher speeds.
    Jan 2008
    Probably better to buy a mill with a 30 taper spindle
    7xCNC.com - CNC info for the minilathe (7x10, 7x12, 7x14, 7x16)
    Oct 2005
    Quote Originally Posted by pippin88 View Post
    Probably, yes.
    But if I could have done that, I probably already would have.
    Yes, the Tormach 1100 MX comes with a BT30 spindle.. but $20k is way outside of my price range.
    In any case, I'm going to explore the idea of building a head stock out of a block of cast iron.
    If I can get a block of G2 or 65-45-12 Dura-bar cast iron about 6"x6" x 10" long I'm sure I could mill it out.
    OnlineMetals lists 6.03x6.03 milled bar, but it's $1100 for a 6-foot piece.
    They say you can request a quote for a shorter cut, a 1 foot piece would probably do.
    https://www.onlinemetals.com/en/buy/...-bar/pid/24200
    Aug 2008
    Not quite sure how the PM-30 compares to the ZX45 in physical size, but I was able to purchase a BT30 spindle to replace the stock R8 spindle that came in my Bolton ZX45 machine.
    I have a somewhat older (& lengthy) thread in the 'RF45 Clone Mill' section of the zone .. Look for 'Bolton ZX45 Conversion'.
    It's towards the very end of my thread where the BT30 spindle went into my machine. Very happy with that change!
    gd.marsh
  7. #7
    Oct 2005
    The ZX45 style is comparable to the PM-932M in that it has the same RF45-based frame:
    https://www.precisionmatthews.com/shop/pm-932m/
    However it's about $800 more than the PM-30MV which I have on order:
    https://www.precisionmatthews.com/shop/pm-30mv/
    It IS a much heavier machine, though.
    And the bed / travels are slightly smaller.
    Do you think it's worth upgrading to the PM-932M for the heavier weight?
  8. #8
    Member arizonavideo's Avatar
    May 2008
    The PM-30 is just large enough for 56C size motor.
    A 2HP with a larger pulley can get you 6 or 8K with good power. The 30 is not that large so 6K with a 1/2 cutter is about right.
    You would need to change to AC bearings. The R8 could be re ground to CAT 30 fairly easy.
    youtube videos of the G0704 under the name arizonavideo99
  9. #9
    Nov 2013
    I'm on a similar project. I have a WMD30 (similar size than yours) with full rail conversion. The weakest point of your mill is going to be the column, I wouldn't spend that much money until you reinforce that column as best as you can.
    After my rail conversion I spected less chatter, but noticed that increased a lot. Now I have bolted the whole column to the cinder block wall and it has got better, but still I'm thinking on filling the block with concrete.
    Anyways, once I actually get the column reinforced enough, the weakest point of my mill is going to be the spindle (MT3 with TTS). The whole headstock is also not that stiff, I think, So my idea is replace the headstock and use the same spindle cartridge. Maybe even modify it to get through spindle coolant...
  10. #10
    Oct 2005
    I'm going to call PM this morning and ask about upgrading to the PM-45/PM-932 instead.
    It'll have the slower RPM geared head, but I think the stronger frame would be a better base to upgrade it from.
  11. #11
    Oct 2005
    Quote Originally Posted by gmoschini View Post
    The order is updated! Will ship by the end of November due to the PM-1030V lathe being on backorder.
    For $1010 extra, I upgraded from a PM-30MV to a PM-932M, with the Power Down Feed and Cast Iron stand options.
    I also added a 2nd 5" vise and ultra-precision collet set.
    I'll have to think about the options for converting its spindle to 1:1 belt drive with servo spindle, and changing the spindle to BT30.
    ArizonaVideo, you mentioned regrinding the spindle to BT30?
    I'd imagine I'd have to get a tool-post grinder to do that... would I do that directly on the mill?
    Or take the spindle out and grind it on a lathe with a 4-jaw chuck?
    I would probably also need to grind slots in the end for the BT30 driving pins... and drill and tap the ends.
    Maybe when the time comes I'll just buy a spare spindle from PM and make the changes on that.
  12. #12
    Oct 2005
    On further review, I am glad I decided on the RF-45/PM-45/PM-932m.
    Charter Oaks Automation has a NT30 spindle that's a replacement.
    eBay also has a ton of NT30 spindles for Bridgeport heads that may also match - at least the bearing diameters are the same, not sure about the length.
