For a plasma cutting and I had one once, you could use or should consider shielded cable for all your inputs. My CNC router uses the inductive/capacitive proximity switches with shielded cable. I believe Mach3/4 has a THC plug in.
https://warp9td.com and they have THC for Mach4 and it looks like voltage is limited to 5 vdc.
