I think I might have damaged a board when I was removing (the board with the aluminum bracket) hit the frame and now the motor wont power. Nothing looks broke or fried, but I can't seem to figure out whats going on. The on/off switch works and stays on, but I get no power to the wires going to the motor. Any ideas where to start or what might have broke?
Don't know that controller, but have you checked the fuses?
Besides the main fuse on the back of the control box, there might be an additional fuse on the PCB which would be either a thinned out PCB trace which would burn or would look like a through hole resistor and that one is not visible when burned.
