Originally Posted by
DLF
How about the Optimum MH25V? You can check my thread related to this machine.
It is a bit more expensive then the BF20 (approx. +1200 euro) but has all the features that you would anyhow later add to the BF20: belt drive, 1.5kW 3 phase AC motor + VFD, 4000 RPM, BT30 spindle with quick tool change, counterbalanced head, +100kg weight, more Y travel.
Therefore the price delta is justified by these stock features. If you were to add these features yourself you would probably spend more money, not to consider the manhours to mod the machine and add them.
Sent from my SM-A520F using Tapatalk
