Need Help! New member - Spindle setup Optimum BF 46 with UCCNC - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Thread: New member - Spindle setup Optimum BF 46 with UCCNC
  1. #13
    Member Lindblom's Avatar
    Apr 2019
    Default Re: New member - Spindle setup Optimum BF 46 with UCCNC
    I've had a extra look.
    The only cabels that is going in and out of the controlbox is:
    In: main power
    Out: Cabels to the motor, emergency stop, cabels to the display for fine feed of spindle sleve
    There is no general purpose connector or similar.
    The X connections are marked on the bord, some are almost not visable anymore. Se pics of X3, X6 and X7
    I've taken a pic of the back of the LCD-display
    I should be thanking you for you're patience!
    Best Regards
    Attached Thumbnails Attached Thumbnails New member - Spindle setup Optimum BF 46 with UCCNC-x3-jpg   New member - Spindle setup Optimum BF 46 with UCCNC-x6-x7-jpg   New member - Spindle setup Optimum BF 46 with UCCNC-back-display-jpg
  2. #14
    Apr 2009
    So controlling spindle operation will be doable via analysis of your reversing switch.
    This switch will most likely have a voltage or ground that is switched when you turn it. This will be hooked to relays used to control spindle direction. You may need a third relay to do spindle on-off.
    The other part of it is that potentiometer. You should check what’s it’s input voltage is and what happens when you turn it. It may be possible to use a PWM spindle controller hooked to that switch to change the speed.
  3. #15
    Apr 2009
    https://cnc4pc.com/c6-variable-speed-control-board.html
    This is the control board I use for this.
  4. #16
    Apr 2009
    Also a point of annoyance - your controller may closed loop operation. Or the encoder may only drive the LCD.
    The mechanism I use does not support closed loop - and you cannot do closed loop straight off of the UC100 unit with the encoder feedback. That means no rigid tapping. Only the UC300 is powerful enough.
