Yeah, I know what you mean
First part will be a small bearing holder for the floating end of the X axis to hold an angular type. After my last teardown the X axis backlash went to 0.035mm (to do with the bearing).
I found out that if I put the bearing tight up to the ballscrew on that end instead of it 'floating' the backlash then drops to 0.01mm rather than the 0.035 as is now.
If I know it'll work I may as well do it.
Then at some stage it's a 17mm head spacer so I can use the extra Y travel. My throat is 183mm allowing the rubber material on the roller some room. The extra 17mm will get me the full 200.
