Replacement Drawbar for RF-25
Results 1 to 2 of 2
Thread: Replacement Drawbar for RF-25
    Jul 2016
    Default Replacement Drawbar for RF-25
    Hello,
    I have an Enco/Rutland RF-25 clone, and the upper hex part of the drawbar came loose. I ordered a "replacement" from Grizzly for their G0760 (an RF-30 clone), and it came a little too long and, as it turns out, did not run true. I may have to end up trying a replacement part for the RF-30 from a different manufacturer and then cut off the excess length of thread so it can fit in my machine, however it would be better if I could find one that is made to fit my particular machine (or at least a little closer to it).
    Does anyone know where I could find a replacement drawbar for my RF-25? My searching did not produce any result. Any help would be greatly appreciated.
    Thanks guys and gals!
    Cheers,
    IHateMayonnaise
    Jan 2005
    Default Re: Replacement Drawbar for RF-25
    Most of the drawbars on those type machines have a hex with a bore that the long drawbar shaft inserts into and is pinned. I had a RF-30 clone that was that way and it also came loose because they used a roll pin that sheared off. You should be able to simply remove the remnants of the roll pin with a pin punch and then put a new one in, or just put a bolt in it.
