If you plan to do manual milling to "practice", then leave the acme screws in there until you actually do the CNC conversion. Ballscrews can be back-driven leading to axis creep under manual use if you forget to lock the unused axis on the table during a cut. An acme screw has enough drag that it can't be back-driven.
