60" x 40" new build - Page 4
Page 4 of 7 FirstFirst 1234567 LastLast
Results 37 to 48 of 75
Thread: 60" x 40" new build
  1. #37
    Activation process Jdubya's Avatar
    Oct 2018
    Default Re: 60" x 40" new build
    Quote Originally Posted by ger21 View Post
    No, you're power supplies are fine.
    Great! Again, thank you for your help. 2010 Screws are ordered. Will order these tonight. Back on track. Soon ill have enough extra parts to build a second machine.
  2. #38
    Oct 2018
    Now im thinking about moving the screws to the outside of the ibeam again, so i can connect my table to the side rails better.
    Easy enough i guess. These new 2010 screws may not fit where the 1605's are currently located. Its pretty tight now. Well see.
  3. #39
    Oct 2018
    I have an ESS wiring question about this diagram from automation technology. It shows 5v going into the ESS and then out of the terminal board and supplying all 4 drivers with 5v. Is that correct? I have a clean 5v 5a power supply, i was going to run 5) 1 amp fuses to the ESS and the 4 drivers.
    8070D driver Box Wiring (4821)
    https://www.automationtechnologiesin...oad.php?id=365
  4. #40
    Oct 2018
    So... I guess that was a dumb question... I will stick to the diagram. Lol. . I got my power supplies, ESS, drivers mounted in a pc tower. Just about ready to wire it up.
    My bk15's and bf15's came in, they are larger than the bf/bk12's of course, so i will be moving them to the outside rail afterall.
    The nema 34 640's are in, just waiting on the new 2010 screws now.
  5. #41
    Oct 2018
    My build was taking up too much of my workspace at work, so i have taken it home to finish.
    Last week i was given a lincoln 275 square wave tig machine and i sent the control board out for repair and I've hunting down tig accessories.
    New ballscrews came in. I think i have their location figured out now. My controller box is almost done.
    Hurry up and wait....
  6. #42
    Jan 2005
    Quote Originally Posted by Jdubya View Post
    Looks like i can swap out the 1605's for 2005's if my long axis is too slow for a few hundred bucks if needed to gain more RPM's. Are 2005's big enough for that 60" length @ Skrubol for higher rpm's?
    Your screw pitch is where you can gain speed 2005 is 5mm pitch this 5mm pitch is normally used for the z axes if you are going to change them get 10mm pitch screws 2010 ballscrews this will double your machine speed with the same RPM
    Mactec54
  7. #43
    Oct 2018
    Thanks, i did replace the long axis 1605 screws with 2010 screws after all.
  8. #44
    Oct 2018
    I would have used 4" ibeam looking back now so the 2010 ball screw bearing blocks would have fit very cleanly inside the ibeam but this will have to do for now.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20181126_172348-jpg
  9. #45
    Oct 2018
    Got my welder repaired but I need to grab some argon from work. Made some aluminum parts. The uprights came out pretty well. It's as square as i can make it anyways. Sure moves nice and is solid even with only 4 top screws holding it together. Ready for the backplate now.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20181209_172424-jpg
  10. #46
    Oct 2018
    Getting close to finishing my Y axis. It's boxed in anyways. Now i can start laying out my X axis.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20181228_172931-jpg
  11. #47
    Oct 2018
    X axis getting close.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20190121_164312-jpg
  12. #48
    Oct 2018
    640oz nema 34 with 1610 ball screw for the x axis.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20190122_192623-jpg   60" x 40" new build-20190122_192747-jpg
60" x 40" new build
60" x 40" new build
