60" x 40" new build - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 118
Thread: 60" x 40" new build
  1. #41
    Activation process Jdubya's Avatar
    Oct 2018
    Default Re: 60" x 40" new build
    My build was taking up too much of my workspace at work, so i have taken it home to finish.
    Last week i was given a lincoln 275 square wave tig machine and i sent the control board out for repair and I've hunting down tig accessories.
    New ballscrews came in. I think i have their location figured out now. My controller box is almost done.
    Hurry up and wait....
  2. #42
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Jdubya View Post
    Looks like i can swap out the 1605's for 2005's if my long axis is too slow for a few hundred bucks if needed to gain more RPM's. Are 2005's big enough for that 60" length @ Skrubol for higher rpm's?
    Your screw pitch is where you can gain speed 2005 is 5mm pitch this 5mm pitch is normally used for the z axes if you are going to change them get 10mm pitch screws 2010 ballscrews this will double your machine speed with the same RPM
    Mactec54
  3. #43
    Oct 2018
    Thanks, i did replace the long axis 1605 screws with 2010 screws after all.
  4. #44
    Oct 2018
    I would have used 4" ibeam looking back now so the 2010 ball screw bearing blocks would have fit very cleanly inside the ibeam but this will have to do for now.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20181126_172348-jpg
  5. #45
    Oct 2018
    Got my welder repaired but I need to grab some argon from work. Made some aluminum parts. The uprights came out pretty well. It's as square as i can make it anyways. Sure moves nice and is solid even with only 4 top screws holding it together. Ready for the backplate now.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20181209_172424-jpg
  6. #46
    Oct 2018
    Getting close to finishing my Y axis. It's boxed in anyways. Now i can start laying out my X axis.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20181228_172931-jpg
  7. #47
    Oct 2018
    X axis getting close.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20190121_164312-jpg
  8. #48
    Oct 2018
    640oz nema 34 with 1610 ball screw for the x axis.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20190122_192623-jpg   60" x 40" new build-20190122_192747-jpg
  9. #49
    ericks
    Guest
    Looking good!
  10. #50
    Oct 2018
    Thanks! This has been much harder than I anticipated. Lol. Free time is rare..
  11. #51
    ericks
    Guest
    I agree!!
  12. #52
    Oct 2018
    Curious about wiring this box to the motors, i found some 18awg ingus chainflex 4) wire but its not shielded..
    Then i have some shielded 18awg but it not real flexable.
    Is there shieded chainflex? Thoughts?
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20190123_180240-jpg
  13. #53
    Jan 2005
    Chainflex type cable is only needed for any cables that are in your cable tray outside your cabinet, Shielded for motors cables and spindle to VFD, inside your cabinet you can use Twisted pairs
    Twist your cable like this, you can get in any color from McMaster-Carr
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-16-gauge-24a-cable-png   60" x 40" new build-hpim2919-jpg
    Mactec54
  14. #54
    Oct 2018
    Thank you! That helps.
  15. #55
    Oct 2018
    Y axis motor mounts cut and tacked in place.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20190126_153539-jpg
  16. #56
    Oct 2018
    Getting my Z axis motor mount design figured out. My spindle is about 1/4" off of center to my gantry on the long Y axis.. I think i can live with it anyways. I can see light at the end of this tunnel..
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20190130_165859-jpg
  17. #57
    Oct 2018
    Z motor mounts
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20190131_134740-jpg
  18. #58
    Oct 2018
    Spindle is mounted. All the way down on Z is right at the top of where my table will be. Perfect!.
    Ready to wire after i add a few more bolts.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-20190201_182458-jpg
  19. #59
    Oct 2018
    For ess wiring question, one of these drawings must be wrong?
    I want to use grounds right? One pic sends 5v to each driver pul and dir. Thats not right is it?
    The second picture seems right.
    Attached Thumbnails Attached Thumbnails 60" x 40" new build-screenshot_20190222-201601_drive-jpg   60" x 40" new build-screenshot_20190222-201436_drive-jpg   60" x 40" new build-jinan2ess-1-pdf
    Attached Files Attached Files
  20. #60
    Oct 2018
    I guess i will just try it, one way. If it does not work, ill try it the other way. Hmm
60" x 40" new build
60" x 40" new build
