- How do you control spindle speed?
Activation process
As the title, what wiring, parts etc are required for a brushless variable speed mill?
Re: How do you control spindle speed?
There are three popular ways to control spindle speed.
- Through RS-485. You need a VFD/BLDC drive with RS-485 interface and an RS-485 port on your computer (typically a USB adapter).
- Through 1..10V. Most VFDs and BLDC drives have this input. You need either a breakout board with 1..10V output, or a PWM output and a converter.
- Through PWM. Some (but not all) BLDC drives have that option. You need one spare digital output on the breakout board for PWM.
Junior Member
Maybe change the speed control from the pot to the VI/ACM inputs?
https://openclassrooms.com/en/membres/gary-foley
- You may not post replies
- You may not edit your posts
Forum Rules
