This set?
https://cnc4pc.com/dmm-dyn4-servo-kit-1800w.html
Has a lower rpm than the one I looked at so you'd need a 1:2 ratio to max the spindle to 6krpm.
However the torque rating on it looks pretty big to overcome that.
Looks good.
Have you integrated it into Linux for spindle control?
For future reference could I be cheeky & ask
1: Do you have it set for speed or torque mode?
2: Which JP4 connector pins did you use for (on/off, fwd/rev, 0-10v +/-)
I think that's all I'd need to know unless there's anything else useful you suggest.
I use Mach3 but it's more or less the same outputs to run it.
Thanks.
Daz.
