Is a 400w servo adequate for RF-45 Z-axis?
Results 1 to 4 of 4
Thread: Is a 400w servo adequate for RF-45 Z-axis?
    Mar 2017
    Default Is a 400w servo adequate for RF-45 Z-axis?
    Hi pretty much as subject says, is a 400w servo adequate for RF-45 Z-axis? I am picking up some older DMM 400w servos (60EM-DHT-36) and I'm wondering if they'll move it up and down if I counter weight it.
    Feb 2012
    Default Re: Is a 400w servo adequate for RF-45 Z-axis?
    If it is truly counter weighted it will move up and down with the touch of a finger. Meaning the counter weight is the same as the head . But if you just did the weight less than the head you still have head weight to help eliminate vibration and your motor will still lift it.
    Quote Originally Posted by j3dprints View Post
    Sent from my SM-G900R4 using Tapatalk
    Member mactec54's Avatar
    Jan 2005
    They might work, the Z axes is always a challenge, on these machines a 5:1 gearing might be where you need to be even with it balanced with a counter weight, 3:1 may work would be a good starting point, they will work on the X and Y with 2:1 gearing
    Mactec54
    Member arizonavideo's Avatar
    May 2008
    How much toque at 1000 RPM?
    youtube videos of the G0704 under the name arizonavideo99
