G0704 Wont power on
Results 1 to 7 of 7
Thread: G0704 Wont power on
    May 2017
    Default G0704 Wont power on
    I've had this mill for a year and a week so well its out of warranty. I was running the mill for a few hours straight on Sat. nothing too heavy max was about .050 cut and the power kicked off on the machine. I attempted to start the unit back up and nothing so i left it unplugged and tried to start it up the next day the mill still wont power on. I have checked both fuses and verified that I'm getting power to and through the switch along with 110 at all the connections in the wiring diagram that shows. but the tach wont power up and nothing happens. I have read about people having motor problems but nothing turns on I would assume that if it was the motor at least i would be able to get the display to turn on. Is there a way to test the motor itself to see if its control boards or the motor.
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: G0704 Wont power on
    having a quick look at the diagram on page 45
    http://cdn0.grizzly.com/manuals/g0704_m.pdf
    G0704 Wiring Diagram.pdf
    with no display on the tachometer
    I would have a look at the Guard Limit Switch
    the switch could be faulty or not being closed when the guard is in position
    the switch is connected to PCB CESX 1101-28 that will be the DC power supply and interface for the tacho module
    PCB CESX 1101-28 will also be part of the interlock that ensures you start the spindle with the spindle guard in place
    photo found on the net
    G0704 Wont power on-cesx-1101-28-jpg
    John
    PS
    does the no volt release on/off switch latch on
    May 2017
    Quote Originally Posted by john-100 View Post
    John
    PS
    It will probably be friday before I get a chance to look at that. I am not really sure what you are saying in the PS. I did notice that when i was in the case some of the nuts had vibrated loose and were sitting in the case.
    Mar 2007
    uk
    if the machines on/off switch is the type I think it is
    G0704 Wont power on-volt-release-switch-jpg
    when terminals A1 & 24 are connected together
    the switch will remain on when the green button is pressed
    the coil is energised and will hold the switch on (latch on)
    when the connection between A1 & 24 is broken the coil is no longer powered and the switch will open
    G0704 Wont power on-volt-release-switch-connections-jpg
    note - this is the 240V version of the switch
    looking at the photo of the JS239508253GB
    this is what I see
    G0704 Wont power on-cesx-1101-28-connections-jpg
    1) a mains filter ,
    mains filter circuit
    G0704 Wont power on-mains-filter-jpg
    2) a step down transformer , bridge rectifier & capacitor and 5V regulator IC
    making a simple linear power supply to power the tachometer module
    I expect the power supply & connections to the tachometer module
    will be like this
    G0704 Wont power on-cesx-1101-28-psu-jpg
    a detailed photos of the both sides of the board
    will help to reverse engineer the board to create a circuit diagram / schematic
    the odd thing following the wiring diagram the live supply passis through a 15A fuse that is connected to the "N in " as marked on the CESX 1101-28 PCB !!!!!
    the neutral going to the "L in "
    more of an issue is the guard switch breaking the neutral to the on off switch
    looking at how the no volt release switch is wired
    when a spindle direction is selected
    terminals 9& 10 are closed connecting A1 & 24 on the on/off switch
    this powers the solenoid in the on/off switch and enables it to latch on when the green button is pushed
    switching the spindle direction to off , pressing the red stop button or opening of the guard switch
    will cause the on /off button to switch off
    A break in the wiring between terminal 24 on the on/off switch and the transformer
    would cause the loss of power to the tachometer
    John
    Last edited by john-100; 08-30-2018 at 11:10 AM. Reason: add tachometer 5V power supply circuit
    May 2017
    this is what I see
    1) a mains filter ,
    will be like this
    John
    John I had one of the guys stop and check the switch to see if it would latch on it didn't appear to. I will be up there tomorrow afternoon to look at it some more.
    -Kyle
    May 2017
    I just want to thank everyone I pulled the switch and started probing the wires leading to the switch and all appeared to work bypassed the chip guard safety switch unit powers up and operates normally now if i could just get the rpm to read again its been straight 0000000 for the last few months.
  7. #7
    Mar 2007
    uk
    if the tacho sensor on the G0704 is like the sensor on other lathes I have looked at
    the 3 core cable is soldered to the sensor PCB and can easily break and
    if the board moves its possible for the slotted disk to damage the optical sensor
    sensor
    G0704 Wont power on-slotted-optical-sensor-png
    sensor PCB
    G0704 Wont power on-sensor-pcb-circuit-png
    sensor cable
    G0704 Wont power on-tacho-sensor-cable-jpeg
    John
G0704 Wont power on
G0704 Wont power on
