New Machine Build lil' old mill
Results 1 to 19 of 19
Thread: lil' old mill
    Jul 2005
    England
    Default lil' old mill
    So, I started this project back at uni, 12 years ago.
    When I graduated in 2007, this is what it looked like...
    lil' old mill-mill1-jpglil' old mill-mill2-jpglil' old mill-mill3-jpg
    It was a shiny beast back then, surface ground blocks of stress relieved steel and iron.
    Too heavy to (sensibly) carry as it should be.
    But alas, the responsibility of adulthood left me wanting for time to work on it, and with changes in job, I lost access to the much needed machine shop to continue.
    I fitted the motors back in 2012 and that was it for 6 years.
    And for 6 years, it has sat in my home shop, untouched, unloved. Slowly loosing its shine, its ways hidden by dust...
    Until about a month ago, and like the phoenix, it is rising from the depths of the (man) cave to be born anew...
    Pics and progress to follow
    Last edited by i_am_fubar; 08-22-2018 at 02:21 AM. Reason: Images Added Internally
    Jul 2005
    England
    Default Re: lil' old mill
    Started on the Z. construction is a 100x100, 10mm wall box section steel with 25mm plates bolted to either side for the rails:
    lil' old mill-maching-milling-z-slabs-jpg lil' old mill-wp_20180802_19_18_46_pro-jpg
    lil' old mill-wp_20180802_20_25_23_pro-jpg lil' old mill-wp_20180804_20_41_46_pro-jpg
    lil' old mill-wp_20180805_13_12_08_pro-jpg lil' old mill-wp_20180805_19_51_05_pro-jpg
    lil' old mill-wp_20180805_19_51_00_pro-jpg lil' old mill-wp_20180805_19_54_43_pro-jpg
    And for the record, those are steel toecap sandles
    Jan 2016
    I like it. I'm really curious on the details, I'm designing an epoxy granite machine around the same size to replace my G0704. Is there a build log of the original?
    Are you worried about resonance in the boxed section? What size rails are you using? What kind of spindle?
    Do you happen to have the table dims and a source?
    Sorry for all the questions lol
    Jul 2005
    England
    Just quickly before I head home....
    I think it's a Taig bed. The linears are 20mm THKs I think (This was all back at Uni and details are sketchy )
    Z will have 15mm Hiwins and 15mm ball screw. Spindle is 1.5kW watercooled with ER11 collets.
    If I have any resonance issues with the box, I'll fill with sand. But I'm giving it the old 'hit it with a spanner and see if it rings' test. So far, it goes 'clonk' and that's it
    Will try and get some specs tonight along with more Z updates.
    Jul 2005
    England
    Well, as of this evening, this is the state of the mill, dummy steel represents Z.
    Base is a solid plate of cast iron 50mm thick with 25mm steel plates either side.
    lil' old mill-img_2111-jpg lil' old mill-img_2117-jpg
    Confirmed 200x200x200mm travel.
    lil' old mill-img_2120-jpg lil' old mill-img_2121-jpg
    Poor rusty motor mount.
    lil' old mill-img_2112-jpg
    Underside of X axis (table)
    lil' old mill-img_2116-jpg
    Current Stand Status with space for le' handy electronics
    lil' old mill-img_2118-jpg lil' old mill-img_2119-jpg
    Jul 2005
    England
    So, these are my steppers, reclaimed from a skip. Does anyone know ANYTHING about this brand/make? Greatly appreciated if you do, all I know is that it's a FEA2M55
    lil' old mill-img_2123-jpg
  7. #7
    Jul 2005
    England
    So, the X&Y assembly hasn't been touched for about 5 years, hence the surface rust.
    As for the Z axis. It's been the most recent work (read, last month of so). And that has gone from nothing but a pile of scrap steel to this.
    lil' old mill-img_2124-jpg lil' old mill-img_2125-jpg
    lil' old mill-img_2126-jpg lil' old mill-img_2127-jpg
    The spindle and box section are just mock ups for now. Spacer still to be designed.
    Next job is to get the ball screw mounted. Going to be tricky as I'm having to mount a bearing at either end and pre-load together down the whole length of the screw. Second hand screw had had it's locknut thread cut out for some reason.
  8. #8
    Jul 2005
    England
    Got the Z linear components finished over the weekend. Despite some initial worries that some of the components may not be square enough, playing around with the 20 adjustment bolts has left it with almost zero binding, am very happy with it.
    lil' old mill-wp_20180827_19_14_22_pro-jpg lil' old mill-wp_20180826_21_51_37_pro-jpg
    lil' old mill-wp_20180826_21_39_40_pro-jpg lil' old mill-wp_20180827_19_39_55_pro-jpg
    I need to start thinking about how I'm going to finish it. I could leave it bare steel and just accept the surface rust will be an inevitability if I don't keep it oiled. Or I can paint it. What do you guys think?
  9. #9
    Jul 2005
    England
    There is something nice about being able to take scrap blocks of steel and make them into something usable
    lil' old mill-wp_20180826_21_40_24_pro-jpg ----> lil' old mill-wp_20180826_21_39_40_pro-jpg
    Can't wait to see what I can do with a CNC.
  10. #10
    Jul 2005
    England
    With the Z mounted, the next thing to do is make a mounting bracket to hold the spindle to the saddle. I'm putting the spindle in the middle of Y movement for the biggest cutting area, which means it need to be about 100mm high.
    Decided to use some spare 100x100 section (left over from the body of the Z), 12mm plate for the spindle to bolt to and 20mm thick block inside the tube for the saddle to bolt to.
    It'll hopefully be the only welded assembly on the actual mill (except for maybe covers / guards), but I don't want it to look out of place, so it'll get a full re-machine after welding.
    Bits machined and assembled.
    lil' old mill-wp_20180830_21_08_43_pro-jpg lil' old mill-wp_20180830_21_15_25_pro-jpg
    Got a friend to weld it together and then faced off when I got it home. I was considering welding it myself, but 1) I don't have the most powerfull MIG, 2) My welds are just a bit pants and 3) He has access to a industrial beast.
    lil' old mill-wp_20180831_19_42_42_pro-jpg lil' old mill-wp_20180831_20_12_11_pro-jpg
    These holes will bolt to the Z saddle plate (4x M12) with the spindle mounted on top like so:
    lil' old mill-wp_20180831_21_16_17_pro-jpg lil' old mill-wp_20180830_21_15_54_pro-jpg
    Probably go for M12 on the spindle - spacer interface. But need to skim the spindle mount, it's a horrible aluminium casting, but does the job with some decency. I may, if I can find a decent source of a steel block, make a steel one. orrrrrr get an ATC if the boss lets me. Maybe once it's up and running
  11. #11
    Member CS900's Avatar
    Aug 2006
    looks like it'll be a stout little mill for sure!
  12. #12
    Jul 2005
    England
    Yea, Stout is a good word. Thankfully, I didn't go too big as doing anything this size on a Chester 626 mill requires some horrible setups.
    Managed to get the spindle mounted, only to find I've got bolt heads hitting bolt heads, so need to do some re-work. But I'm happy with the rigidity.
    lil' old mill-wp_20180901_15_54_28_pro-jpg lil' old mill-wp_20180901_19_21_13_pro-jpg
    Also machined the plate for mounting the top stepper. This was a REALLY nasty bit of plate that I had used to smash rocks on, so excuse the nasty
    lil' old mill-wp_20180906_20_33_01_pro-jpg lil' old mill-wp_20180906_20_53_55_pro-jpg
    As for the top of the column though, it wasn't square, straight or anything, so had to mill the whole thing. Through 4 operations, with terrifying clamping methods, each clocked in individually. But the end result is nice and square.
    lil' old mill-wp_20180805_19_51_05_pro-jpg lil' old mill-wp_20180912_20_32_41_pro-jpg lil' old mill-wp_20180912_20_57_57_pro-jpg
    Got to drill and tap the column to mount the stepper plate tonight. Will be a mark out and pillar drill job, so fingers crossed for accuracy.
  13. #13
    Jul 2005
    England
    Bit more work getting the last of the Z machined and fitted. But in theory, this thing could start cutting with the electrics. So, machinist hat off, sparky hat on.
    lil' old mill-wp_20180914_20_52_23_pro-jpg lil' old mill-wp_20180915_15_24_02_pro-jpg lil' old mill-wp_20180917_20_07_48_pro-jpg
  14. #14
    Jul 2005
    England
    IT LIVES!
    VIDEO!
  15. #15
    Sep 2007
    Congrats! What an awesome build. I wish I had the equipment to work steel like that.
    Just curious, as I've been researching motor/shaft couplers for my CNC project recently, are those helical couplings suitable for a machine as "stiff" as a mill should be? Wouldn't the mass of the table cause the coupler to stretch or compress axially when the motor accelerates?
  16. #16
    Jul 2005
    England
    Cheers The shaft couplings will suffer some torsional stretch, but unless it becomes a problem during test, I'm going to ignore it
    I'm planning on doing some acceleration tests when the mill is next together (currently disassembled on bench while I work on the mounting table).
    Did get a quick video of repeatability though:
  17. #17
    Jul 2005
    England
    So, there has been some more movement. I added an old desktop PC (With a 5.1 surround sound system because, why not). Spindle coolant is in. Made a mister (although that needs testing) and it's had all the swarf guards and limit switches added. Will get some more pictures as and when I can.
  18. #18
    Jul 2005
    England
    I think.... I'm about finished.
    Except for
    - Coolant
    - Mister
    - Compressor
    - Feeds and speeds
    - Cleaning electronics cabinet
    - Better cable routing
    - Limit for Z homing
    - Better desk for keyboard and mouse
    - Network connectivity
    - 4th Axis
    - Laser cutter head
    - Lathe spindle attachment.........
  19. #19
    Jul 2005
    England
    Oh, and it makes chips (takes a while for spindle to register full speed.... needs an encoder)
lil' old mill
lil' old mill
