Now looking at fittings for it.
I'm planning to Y split into 2* 6mm lines from the lube pump first, one to the head and one to the table.
Fit a non-return valve at the end of each line then go into manifolds. Then use 4mm lines out to each area.
1st thing is I'm unsure whether to fit the ballnuts to the oil system or to use grease/gun via grease nipples fitted on the side of the machine through separate lines going to the nuts.
Are the fittings overkill or will it be a reliable system once dialed in correctly? Or would you do it differently.
Based on what I've looked at above I'm hoping to spend less than £175GBP total.
