CNCL seems to be good, so all I need to use it is a Arduino Uno connected to a PC (Windows 10). I already have the breakout board that I ordered from CNC drive.Drivers I can possible use the leadshine ones.
I have a few questions regarding this setup.
1. Do you have noise issues, I mean the arduino getting effected by noise from the motors or via USB and it behaving erratically?
2. How did you connect the spindle motor for threading, I believe you left the original spindle motor as is for normal lathe operations and you added another stepper for threading etc. So you connected both via belt drive to the final chuck shaft?
3. For spindle is your existing motor an ac induction motor?
