Hi Ian,
Normally you are right. But I have found swarf mixed with the ACME leadscrew grease. Therefore definetly a full table + saddle disassembly and cleanup was necesary.
And yes, this helped the measurement process needed for the CNC retrofit.
In the end all was good, the bad parts will be replaced under the warranty andd soon I will be able to proceed with reassembly.
A.
Sent from my SM-A520F using Tapatalk
