Problem array of posts: does this tool exist? - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Thread: array of posts: does this tool exist?
  1. #13
    Gold Member
    Jan 2005
    Default Re: array of posts: does this tool exist?
    He did not mention manual mill, asked about using a CNC mill, still easy also to do on a manual mill
    From Post #1:
    Is there a specialty endmill with blades facing inwards, to create the posts in one cut, and 'fill in' the unmilled surfce with a regular mill? Googling did not produce a result. Or is CNC the only method to achieve this?
    From Post #2:
    Upd: Sherline mill, can get to a Bridgeport.Upd2: Rotary table and regular mill?
    No mention of the sherline or bridgeport being CNC
  2. #14
    Gold Member
    Jan 2005
    What's a bench top mill got to do with it, you would have a hard time putting any of my machines on a bench
    Ummmmmmm....... This is the BENCHTOP MACHINES forum
  3. #15
    Nov 2015
    UK
    Many thanks, 109jb , a boring head is exactly what I need.
    Sorry, folks, that I haven't mentioned that my machine (Sherline) is manual. No CNC.
    I have, indeed, considered pins at first, but posts would have holes drilled and tapped in them. I.e. the posts serve to align and to hold the mating part that would have matching slide-fit holes. Pins would get pulled out otherwise.
    Last edited by runcyclexcski; 12-30-2017 at 07:35 AM. Reason: more precision/accuracy
  4. #16
    Gold Member
    Jan 2005
    Quote Originally Posted by 109jb View Post
    From Post #1:
    From Post #2:
    Quote Originally Posted by runcyclexcski View Post
    Sorry, folks, that I haven't mentioned that my machine (Sherline) is manual. No CNC..
    As you can see I replied to the first post, never looked at his second post, anyway a core drill would do what he wants to do, and he could even make the core drill himself, very simple way to do it
    Mactec54
