Build Thread PM45 mill upgrades - Page 8
Page 8 of 10 FirstFirst ... 5678910 LastLast
Results 85 to 96 of 109
Thread: PM45 mill upgrades
  1. #85
    Feb 2012
    Default Re: PM45 mill upgrades
    Quote Originally Posted by CS900 View Post
    A little time with the dremel and few shims later and it's looking much better:
    Getting so close . Can't wait to see some chips and what kind of rapids it can do safely.
    Sent from my SM-G900R4 using Tapatalk
  2. #86
    Registered CS900's Avatar
    Aug 2006
    Quote Originally Posted by gearhead406 View Post
    Thanks. I was messing around with the motor tuning last night, and I'm sitting at 180IPM at an accell of 60 in/sec^2 for x and y. The motors don't even give the slightest hint they are having a hard time. The z axis on the other hand id geared down 3:1, so the stepper is spinning super fast and i can hear it bogging down around 100 IPM @ 60 in/sec^2. I may switch it over to direct drive like the x and y, but for now, I've turned it down to 80 IPM, which is plenty quick.
  3. #87
    Mar 2017
    Did you square the head to the column before squaring the head to the base?
  4. #88
    Aug 2006
    I squared the rails on the column to the table before tramming the head if that's what you mean. There is about .001" deviation over 6" in one direction, and around .002" normal to the first direction. The thinnest shim i have are .001 so it's as close as i could get without scraping the surfaces. Given that it is still a import mill when it comes down to it, i don't think that's too bad.
    Also Facebook reminded me that 5 years ago today I got this mill. What a different beast it is now. And also my old 323 GTX in the background...
  5. #89
    Aug 2006
    Well it's been a while since any real update, but I assure you i have not been at rest. My biggest hurdle now is getting a chip cover for the Z axis. After looking around trying to find one that I can adapt to my use, I've decided that I'm too cheap and I should try making my own. So I've been trying different combinations of materials to get the chemical resistance and structural rigidity that I desire. So fast forward thru lots of failed attempts and I think I'm headed in the right direction. I bought a 1/16" thick sheet of buna-n rubber that I'm going to use as the external surface. Great water and chemical resistance, but it's pretty floppy by itself and will never hold a bellow shape. So I went off to the hardware store trying to find something that's flexible but stiff enough to hold the rubber in place. After stumbling around for a half hour I wandered into the window section and saw it....Aluminum window screen....It's everything I needed and super cheap...So the real challenge was how the heck do you secure it to the rubber...My first attempt was contact cement, and while it worked OK, it wasn't quite the end all solution.
    !st, I needed a backing material so the cement wouldn't stick to itself when folded. I tried plain old paper and some scrap fabric I had kicking around. The paper worked REALLY well while the fabric just let the cement ooze thru. The problem now was after bending it back and forth a few dozen times, the aluminum separated from the rubber.
    So thinking, i remember they sell buna-n oring chord that you can glue together, so a quick google search later I found out that the glue they use is nothing more than common household super glue. That worked GREAT
    So I think I've gotten the pieces together, now I just need to figure out how to fold it to get the shape I want. That said, I'm open to suggestions on better methods....
  6. #90
    Feb 2012
    https://app.alibaba.com/dynamiclink?...areScene=buyer.
    I'm not sure if this link will work but try this.
  7. #91
    Aug 2006
    I'll keep those in mind, but I've committed myself to making this work...at least for a little while, haha.
  8. #92
    Aug 2006
    She's making chips! The new cover, while very ugly, is working great so far.
    So here's the first part:
    Total cycle time was around 15 min, but the stock is much larger than needed so there was a lot of roughing. I'm still not overly happy with the rigidity of the head. I roughed it out with a .5" 4 flute corncob rougher and ended up dialing back the settings until I got around a MRR of 1.9in^3. I realize it's a small machine, but the table and column are pretty solid. It seems like all the vibration was happening at the headstock. Probably running a smaller tool faster would yield better results as well.
    Dimensionally, the part is near perfect. Everything is under .001 from nominal. The surface finish looks much better in person and was done with a 3 flute .25 high helix carbide tool at 60IPM. I'm pretty stoked to do some better testing.
    I currently have the speed of the x and y axis limited to 200ipm, but i have no doubt I could go higher. Accelerations are set to around 60 in/sec^2 and even with my large welded frame shakes the whole mill of rapid direction changes. The Z axis is set to 50IPM. The drive is geared 3:1 down so it's a limitation of the stepper speed. I could go higher I'm sure but I can hear the motor start to get loaded around 80IPM.
  9. #93
    Dec 2015
    It looks very nice. Great work!
  10. #94
    Dec 2015
    The machine looks really good, I like the new cover, seems to contain the system very well. Congratulations on following through and coming to this far. Hope to see much more updates as you continue your progress on upgrading your machine.
  11. #95
    Feb 2018
    They always look worse in photos. I've had great luck with one of those 3 flute roughing mills for AL. I think Niagara makes them.
  12. #96
    Feb 2018
    For the way covers, I was thinking about it, and I may try using some ballistic nylon I have around for mine. I'm just not sure how well a fold will work, but the material itself is nice.
PM45 mill upgrades
PM45 mill upgrades
