Either way would work fine. Using a RT might be easier because most of the work is already done in that the chuck/table is already mounted in bearings. If you start with a harmonic drive, then you have to build the table/chuck/arbor system.
Here is what I did http://www.cnczone.com/forums/linear...onversion.html
