Originally Posted by
gd.marsh
Once bitten by the CNC bug .. it's pretty difficult to shake it off.
You experience so much enjoyment, satisfaction, & sense of accomplishment . . . . . frustration, anger, & expense as you learn how to make your machine do exactly what you want it to.
I doubt that you'll be able to hold 1 or 2 tenths with a Chinese conversion, but if you're doing primarily hobby work plus or minus a few, to several thou is sufficient in most cases.
Unless you already have a fair amount of machining experience you should also consider purchasing cheap end mills to get started .. there's quite a difference in quality between cheap & expensive tooling, but you will likely break or destroy several as you're developing your CNC skills ..
But with all that said .. you've embarked on an incredibly addictive hobby! Best of luck & post pictures of your journey!
gd.marsh
