HI all, looking at putting one of these on a c4 hi torque lathe... Will this control my spindle on and off and speed it up and down? I am trying to achieve full cnc control from a simple cycle start button... so i need it to also do CSS in conjuction with a c3 index pulse card.
Just wondering if anyone has used them and if it will do what i want.
Although Mach won't do G96/G95, it does do G96/G94 great. I use it a lot & the spindle speed increases & decreases with workpiece diameter changes as you would expect with G96. The C41/C3/LMS spindle board combo will give you that capability plus threading if your spindle speed is stable enough under load at low rpms. I think yours should be OK.
My ORAC has a C11 BOB/ C3 index card controlling a 560 watt DC motor with a KB SCR speed control. Works well except for doing threading on larger diameter steel parts. The single pulse doesn't keep things synched up close enough when the going gets tough & the speed varies. I recently purchased an AMC analog servo drive for the spindle which should stabilize things along with the help of the tach generator on the motor.
