I would look at a G0704 from Grizzly. You may want to get the one with the DRO included if you are not going to CNC it right away. One other thing, bigger is better. If you can afford a bigger mill then get it. I wish I had bought a Rong Fu RF45 and converted it. If I had I would not be already thinking about the next "bigger" mill I want to get. Regardless of the size of the parts you currently want to make, you will eventually want to make something bigger. Also, the cost of a cnc conversion is close between an RF45 and a G0704 if you use steppers, so you will get a much better return on your investment from the RF45 if you want to sell it at some point.
