10"x12" Scratch built lathe
Page 1 of 14 123411 ... LastLast
Results 1 to 12 of 168
Thread: 10"x12" Scratch built lathe
    Registered jakemestre's Avatar
    Dec 2009
    Default 10"x12" Scratch built lathe
    Hey Forum,
    I'll start off a new thread about the evolution of my lathe. I started the project about 4 years ago on my high school graduation gift: a 9x20 Grizzly lathe. First it was a VFD spindle,
    then it was a Gecko G540 conversion. At that stage noise was faulting the system and the stock pan was leaking horribly.
    So I started mostly from scratch and built a stand from 1" square tube.
    Then I built a control box where all the wires were shielded and grounded.
    The sliding door was no good so I built a gull hinged door for easy access to the whole machine.
    And these are the two posts. Not enough room for gang style tooling in this machine.
    All the sheet metal was from some guys kitchen floors that I managed to get for a case of beer.
    So after everything is finally running beautifully I get a job for some 1018 steel parts that the machine can not handle. I'm only getting paid about $7per and it's taking the better part of a half hour to turn 1.25" bar stock to an M12x1.5 thread 20mm long. The motor running the spindle is 3hp run off a Lenze/AC Tech VFD, but anytime I run a deeper cut than .02Dia I have to wear earplugs. I tried reinforcing the spindle with some angle iron, but all to no avail. The spindle is correctly preloaded, all bolts are correctly tightened, and the height on all tools is positive with perfect center alignment.
    If you've got some ideas about what's wrong please let me know.
    I need to be able to cut steels(including stainless) and do it in a small production setting. ~100-200 parts.
    So now I'm redesigning the machine from the base up with linear guides, my own 8position turret design, and preferably a D1-4 spindle. I'm shooting for a slanted bed a bit like .
    All of it should fit inside the enclosure I've already spent a lot of time fabricating.
    I've already got the design for the turret, but I need to find a good D1-4 spindle before I start designing the bed, ways, etc.
    Does anybody know where I can find one that doesn't cost an arm and a leg?
    Thanks for the help.
    Jake
    Registered LongRat's Avatar
    Apr 2005
    UK
    Based on the time it is taking to cut such a small amount of material, it could well be that you are feeding way too slowly. Speeding that up might well get rid of all of the screech and chatter. Also, you don't mention what tooling you are using.
    Normally I would have suggested flex in the tool post on a 9x20 lathe as that is a crippling weak link on the machine as I am sure you know, however you have clearly upgraded that weakness very nicely already. Impressive sheet metal work too.
    LongRat
    www.fulloption.co.uk
    Gold Member BobWarfield's Avatar
    May 2005
    Jake, I don't know what you mean by an "arm and a leg" (i.e. what your price range is), but spindles are expensive. You can fairly commonly find 5C collet spindles on eBay from firms like Dunham. They'll be circa $700-900, but should be very nice spindles with sealed precision bearings and so on. If that's too much, you will probably have to look at making your own spindle.
    I have toyed with that idea, even the idea of making one based on bronze sleeve bearings, which would be a lot easier machining job. In the end, I bought a Dunham spindle, which I intend to use for a 4th axis project.
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Apr 2003
    Great looking machine, good job!
    You didn't mention the spindle speed or SFM...too fast perhaps? Can't imagine how a .02 mm (or inch) diameter cut could cause any problems whatsoever in 1018 unless it's WAY too fast?
    Also what does "the height on all tools is positive with perfect center alignment" mean. Perfect center alignment I understand but positive height?
    I have a converted Denford ORAC which is similar to yours in size & construction (except mine has 3/4 hp DC spindle motor) and it'll peel off a decent sized hunk of swarf without a whimper. It's a work in progress and I haven't worked it hard yet. So far the biggest loads I've thrown at it were .060" (dia.) roughing cuts in 3/4" dia. 1018 without a problem.
    Dec 2009
    Quote Originally Posted by LongRat View Post
    Thanks for the suggestion LongRat. I did forget to mention the tooling. I'm using a Sandvik CCMT3251 PF 4215 grade insert. It's in a 1/2" holder that's choked all the way up in the toolpost. I started with the recommended feeds and speeds off the box at .014" radial depth of cut, .004"/rev and 1500SFM. My machine about exploded with chatter with these values so I took it down to the absolute minimum of .004"DOC, .002"/rev and 1500SFM. Still lots of chatter. The spindle is moving relative to the cross slide, but I tightened every bolt and even built some L brackets to help stabilize the headstock.
    The only way I can stop the chatter is at 200SFM, .01"DOC and .oo2"/rev. The part takes 26min at that speed, and I need to make it in 3. The insert is rated to 1950SFM(15500RPM at .472"diameter), .079" radial depth of cut, and .009"/rev. The insert will get me there even for a finishing mid grade insert, it's the machine that won't.
    Gold Member
    Feb 2006
    Seems to me you're expecting an inexpensive, notoriously flexible, hobby lathe to do the work of an expensive tool room lathe. Seems extremely unlikely to me a 9x20 will have the rigidity to exercise that Sandvik tool to anywhere near it's maximum capability.
    Regards,
    Ray L.
  7. #7
    Dec 2009
    Quote Originally Posted by BobWarfield View Post
    Best,
    BW
    Bob,
    Thank you very much for the help. I think I might be able to buy a Grizzly 12x24 spare part spindle for about $600. I'll have to figure that one out, there's no detailed drawing, and it just falls into the arm and leg category. I'll keep an eye on ebay and check in with the local tool distributor to see if there's an old 13 or14-40 lathe for super cheep.
    Quote Originally Posted by DICKEYBIRD View Post
    Thanks for the compliment,
    I posted a quickreply before I noticed new posts. I meant positive rake on the tool. Not positive height. You know I might just try replacing the bolts for the headstock with stainless bolts. That might help a lot.
  8. #8
    Dec 2009
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    Howdy Ray,
    I'm not expecting the 9x20 to perform anywhere near a machining center. I can put these parts on my Tormach and helixmill/threadmill the parts in 4 minutes. I think my lathe should be able to do the same. And now understanding the flexibility of the machine, is why I'm looking for a spindle. I plan to build an entirely new machine that fits inside the enclosure. Something that has at least a 1.25 through bore and a D1-4mount. Also something that's designed with the turret in mind. I appreciate your input.
    Jake
  9. #9
    Sep 2009
    australia
    Hi Jake
    As Ray stated before those figures were only ever intended for large rigid commercial machines. In your case the tool needs to be loaded up a tad more and the sfm dropped heavily , try keeping the sfm between 200-300, Up the DOC to .05" (diameter) and the feed around .005"/rev. If it can't do this I will be surprised
    I have a 7x 12 mini lathe that will take a 2mm cut (.078") in free cutting steel on 1" diameter bar just fine. Just another question how far does your job hang out from the chuck?
    Nice build by the way!
    Cheers Brayden
  10. #10
    Dec 2009
    Hello all,
    I'm sorry I guess I wasn't very clear at what info I was seeking. I'm really just looking for info on D1-4 spindles. Manufacturers, and or build threads on design and construction of a spindle.
    I appreciate all the help with the cut, but my machine just will not remove the material I need. I run a prototype business and everything I make is one off. The problem is that sometimes a prototype requires many turned parts. I never intended my 9x20 lathe to serve as a turning center, but the machine is not meeting a reasonable expectation for turning. So a redesign is in order. I will basically design a new machine that drops into the enclosure I've already built. It will include a turret and tailstock.
    So if anybody has some good info on D1-4 spindle builds that would be awesome. I'll keep this build updated as I make progress.
    Thanks for all the help,
    Jake
  11. #11
    Apr 2005
    UK
    Seems strange, I would think that there is something fundamentally wrong and probably hasn't got anything to do with the modifications you have made. Even an unmodified manual 9x20 machine should be able to do better than this. I would hunt down the cause of this issue before building an entire new machine, that may not be necessary.
    LongRat
  12. #12
    Registered D.L's Avatar
    Jan 2009
    Very neat packaging.
