Ok, just want to make sure I understand what each piece does, so please don't laugh if I get it really wrong:
Drivers:
KL-8056D
--- used to accept signal from breakout board and send to stepper motor(s)?
Yes
PSU:
48 volt Toroidial
--- used to supply power to the entire automation (computer hardware and motors)?
Yes
Breakout board:
C11T Also recommend
PMDX 126 (I will be using this on my Hurco build)
--- used to read code from Mach 3 or similar and generate signals and power to drivers and to motors?
Yes
Steppers: 640oz NEMA34 on lathe Z and 425oz NEMA 23 on the other 2
--- used to physically drive the axis' ?
Yes
Lathe motor:
1hp 3 phase 1800 rpm
--- used to control the lathe separately ? and I assume with the controlling software, possibly simultaneously with the mill if 4th axis operation is desired?
UPDATE: didn't know they already came with two separate motors.... oops.
However, I am interested in linking this motor to exact location so I can use it in that way...so if you know what piece of equipment I would need, just let me know.
I not sure on this one.
VFD drive:
GS2
--- Have no idea whatsoever??
VFD is used to drive the 3 phase motor via single phase 220 volt input. It will make the motor variable speed and can be hooked up to break out board to control FWD,Reverse and speed.
Also, could you list the software you used? and if not too much trouble why you made the particular software choices you made?
