New guy..with a used mill has a question. - Page 6
Page 6 of 6 FirstFirst ... 3456
Results 101 to 107 of 107
Thread: New guy..with a used mill has a question.
  1. #101
    Member Kenny Duval's Avatar
    Jan 2013
    United Stated
    Default Re: New guy..with a used mill has a question.
    So this afternoon was go time. Coolant tank cleaned and a fresh batch of coolant. Found an oil leak a fitting for the oiler system. Fixed that. Found a leak at the pump fittings. Fixe that. Warmed up the spindle and table and setup to recut the piece I ran but failed to complete. Ran perfectly and the finish is great even having re-used the same chip welded end mill after cleaning it up. I simply sounds more solid than the BF20L.
  2. #102
    Jan 2013
    United Stated
    Today's project. A new tool length setter.
  3. #103
    Did you post photos that I'm not seeing?
    I turned my adblocker off for the site thinking photos might appear, and wow, what a hot mess! It hot linked "coolant tank" in your above post to ebay, lol. Terrible bit of advertising.
  4. #104
    Jan 2013
    United Stated
  5. #105
    Those links aren't working either.
  6. #106
    Jan 2013
    United Stated
    Ok...
    They should be working now.
  7. #107
    Jan 2013
    United Stated
    Started working on getting the little BF20L ready to go to a new home. Cleaned up a bunch of the manual machining on the motor mounts,cleaned and lubed everything and did some work on making the power drawbar a bit nicer.
    Before...
    After...
    Ordered some cable chain and some new limit switches and will get all the wiring cleaned up next weekend.
