Originally Posted by
rwskinner
You are most likely aware of this, but a lesson I learned that might be beneficial to you, is to make sure "all" mounting points are machined square to the ways. For example, the front of the machine where your Y axis mount goes, make sure it is flat, and perpendicular to the Y axis ways. I found that there is some filler material used to pretty up the machine and those surfaces, even some of the machined areas are not that square. Even a small variance will introduce an error and cause your ball screws to flex or bind due to misalignment. Another place is the ball nut mounts. Just because it's a machined flat area doesn't mean it was machined on the same plane from the factory. I often wonder what process they use that would allow some of that stuff to be as far off as it can be.
