Build Thread Chris' G0704 build - Page 18
Page 18 of 26 FirstFirst ... 815161718192021 ... LastLast
Results 341 to 360 of 501
Thread: Chris' G0704 build
  1. #341
    Aug 2008
    Default Re: Chris' G0704 build
    For finishing a 4 flute should work just fine, you will have a much thinner cut so shouldn't be an issue with chip evacuation between the flutes.. That will give you an even better finish too and allow increased feed speed for finishing.
    If you use the FSWizard app it will let you change various cut parameters and it will automatically adjust the feed rat e accordingly. I found once you nail down one set of cutting parameters, just make changes to one data point and it will maintain a load that is fairly equal to your known good parameters. So like you said, if depth of cut is shallower and you tell FSWizard that, it will automatically adjust the feed rate appropriately for the new DOC to maintain chip load and keep MRR up.
    Parts look really good! I know what it's like having to haul cords around to equipment. I finished building my house with a 30x60 attached shop and designed everything myself and put a ton of thought into electrical requirements, of course I missed a few minor details but was smart enough to put a panel on each end of the shop and a raceway in the event that happened.
    It's pretty easy to run some wire to add a few 220v outlets, even if you just add receptacles and use extension cords. Copper wire is expensive, bit if you have easy access to everything you can use aluminum and it is a fraction of the cost. Just need to check it every few months to make sure the lugs are tight. I used aluminum in my old commercial building to run outlets for equipment and it needed tightening once in 5 years and it was shortly after initial installation. If they get loose they vibrate and can make a racket.
    I've finally got everything setup so it just have to turn on equipment switches to run something be it on saws, mill, Lathe, or Sanders grinders... Cannot tell you how much easier life is when you don't have to lug cords to each one..lol
    Sent from my XT1080 using Tapatalk
  2. #342
    Member Kenny Duval's Avatar
    Jan 2013
    United Stated
    I ran some new 3 flute carbides for a project on Sunday. I've got to work on my recipe for those. I adjusted using FSWizard to compensate for going from 4 flutes to 3 but it just did not like it. Chattered hard enough to break one and then I broke another when a tool offset failed to be applied. This part requires a good bit of stick out so that didn't help. These are variable flute end mills which in all the research meant possibly less chatter but so far the 4 flute cutter I used last time I cut this part did a better job.
  3. #343
    Aug 2008
    What were the FSWizard numbers?
  4. #344
    Jan 2013
    United Stated
    Now that I looked at it again I forgot to adjust the stick out number in FSWizard. I think I was simply asking too much of the bit and machine. It cut it though until the tool broke. Material removal rate for the numbers I had wrong was 1.04 inches cubed.
    I had good luck with a .003 chip per tooth load on the last run so I tried to maintain that with this cutter.
    .250 3 flute end mill running at 3400 rpm with a .425 DOX x .080 WOC at 30 IPM to reach the chip load number. That was 1.04 cubic inches per minute according to FZwizard.
  5. #345
    Aug 2008
    Is your max rpm 3400? I would drop down to .002" per tooth with that stickout which would drop feed rate to 20ipm especially with long stickout in a small endmill like that. Would be much happier with some more rpm if you have it available.
  6. #346
    Jan 2013
    United Stated
    It is for now as I am still running the gears in the head. I'll belt drive it after the first gear failure. I did drop back a bit on feed after the first break. Rest of the part ran fine. I went by the old it chattered..feed it harder...method. That obviously in this case was not the answer.
  7. #347
    I was trying to use a brand new $43 1" OD x 1/16" wide keyway saw this morning. FSWizard recommended 2400rpm at ~86IPM. I tried a couple test cuts last night and thought I had some workable numbers. I was trying to take a .125" wide cut at 43.2IMP (.0015 IPT) with the entry at 14.4 IPM. Well, the entry cut worked fine but it only made it about 1/4" into the rest of the cut before the spindle stalled. In a panic I hit <Stop> and Mach retracted the head snapping the head clean off the tool. I should have hit the E-STOP instead. It's been a while since I've broken a tool like this and this one stung.
  8. #348
    Aug 2008
    Slitting saws are tough because of coolant primarily they have a tendency to gum up really bad due to friction on the flat surface and a lack of coolant penetration into the cut.. Like cutting with the flutes of an endmill fully buried and no room to evacuate chips..
    I found the best method to use them is to cut in multiple passes and alternative z height per pass. Kind of like deep parting on a Lathe... Cut in some clearance for the tool and don't try to cut deeper than the about 20% of the tooth notch (flute depth) so the material doesn't clog before the tooth clears the stock in its rotation. And lots and lots of coolant!!
  9. #349
    I went back and cut it at 2400RPM, 19.2 IPM(.00067 IPT) , .032" WOC, .062" DOC this morning. Since I'm plunging the saw into the material I reduced the entry feed to 7IPM. That worked, but I feel like I should increase the IPT so I'm going to reduce the WOC to .020" and increase the feed to 28.8 IPM (.001 IPT). The finish cuts are only .005" deep so I'll increase those to 43.2 IPM (.0015 IPT).
  10. #350
    Aug 2008
    How did it work out? This is good information to share with everyone as saws are not the most common cutters used.
  11. #351
    It worked out fine. Now I have a project where I want to cut a slit 3/4" deep though the side of a 1" wide aluminum ring. I think I'm going to buy a 3" x .032" X 30T saw for this job. I'm going to have to run it at 2500rpm to keep the motor in the power curve and take light cuts. I'll try to cut it at 2 depths to keep the side clearance too.
  12. #352
    I got sick of trying to cut aluminum on my 14" abrasive chop saw.It was really slow and tripped the breaker almost every time I used it. I sold it a couple weeks ago and ordered a Evolution Rage 2 multipurpose saw with a 14" carbide tipped blade. I got to try it out for the first time today. I was cutting 3" x 5/8" 6061 bar stock with it. It literally took longer to mark and clamp the material than it took to cut it. I should have bought on a long time ago.
  13. #353
    Aug 2008
    Yeah they rip through aluminum.. You can even use a miter saw saw with a decent blade, I used to use a compound sliding miter saw that would handle 8" width material.. Now I have a cold saw and while not as fast it is a whole lot cleaner without aluminum being shot across the shop..lol.
  14. #354
    Default Chris' G0704 build
    It's been a while since I've posted here. My product sales have dwindled and my business has evolved into more of a mechanical design consulting service.
    I still do some machining here and there though and every time I'm reminded that the "enclosure" I built out of coroplast is a PITA. It's starting to fall apart and I've duct taped the corners together. I hate having to reach over the 20" wall to swap parts or tools too.
    I removed the duct tape before I took this picture.
    I decided that it was time to design a decent enclosure using 8020 rails with a sliding polycarbonate door and coroplast back and side walls.
  15. #355
    Mar 2004
    Wisconsin
    .......with a sliding polycarbonate door and coroplast back and side walls.
    Ya... that is where I am headed too. Well, not completely with 80/20 though. I am thinking of just using "aluminum shape" stock.
    I did not check out coroplast colors yet, but I hope there is a light grey... the white gets dirty looking way too fast. At least when it goes south, it's cheap and easy to replace.
    Chris L
  16. #356
    Here's the design I've come up with:
    Chris' G0704 build-g0704-enclosure-v8-jpg
    On the front there will be a single 48" wide polycarbonate door with a 12" fixed panel at the right end. The door can slide all the way off if needed. The left side will also be clear polycarbonate. The back and right side panels will be white coroplast. The sides will be 36" tall. Hopefully that's enough to keep all of the chips inside.
    The monitor, keyboard, E-stop and pendant will be mounted on the verticals on the left hand side.
  17. #357
    I from finally received all of the parts for the enclosure yesterday. I spent a couple hours drilling the mounting holes in the bottom rails, assembling the frame and inserting the back and right side coroplast panels. On the way to work I picked up the 1/4" polycarbonate front and left side panels.
  18. #358
    Member CS900's Avatar
    Aug 2006
    looks great! are you putting anything in the extrusion to help seal it up against coolant leaks?
  19. #359
    Oct 2013
    Chris,
    A quick question..it that a electrical outlet poking through the enclosure in back of the column? I wonder if that's a good place for it?
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  20. #360
    I'm looking for a window gasket that will work. I've been using a home built fog buster for the last 5 years and it's met all of my needs. My previous coroplast enclosure wasn't sealed on the bottom and I never had any leaks. I'm not interested in running flood cooling if I don't have to.
    Quote Originally Posted by CS900 View Post
Chris' G0704 build
Chris' G0704 build
