Problem Head to Table angel
Results 1 to 7 of 7
Thread: Head to Table angel
    Oct 2004
    Lightbulb Head to Table angel
    Hi everyone that reads this,
    Any input is much appreciated. Here is what I have: I have a Grizzly G8689 mini mill. The head is at a slight angle to the table resulting in deeper cuts by the outside edge of the tool than the inside edge. This makes the work look bad and gives other non-desired affects in the work (Angels on drills, etc.) I have attempted to correct this by using aluminum sheets. I think I have 7 sheets now and I am still not where I think I should be.
    How do others go about fixing the squareness of the head to the table?
    CES
    Member hoss2006's Avatar
    Apr 2006
    Rudydubya shows you how.
    Mini-Mill Spindle-Column Alignment - Home Model Engine Machinist
    Tramming is a must.
    Shop Info
    Hoss
    Gosh, you've... really got some nice toys here. - Roy Batty -- [URL]http://www.g0704.com[/URL]
    Oct 2004
    Default Thanks!!
    Ah the answer and just a few more tweaks and, oh this is the information I was looking for.
    I have heard of the bar method before but did not understand it due to mainly no pics.
    Very cool. There might be a need for a way to control the movement but this will get me trammed in the mean time.
    Member Fastest1's Avatar
    Nov 2009
    I thought this thread had something to do with an angel loooking over you while machining! I needed one. :-) JK
    Oct 2004
    Default Re: Head to Table angel
    Due to a stroke, my left hand is faster then my right.
    May 2013
    Gilligans Island
    I reckon hoss has a 3 bolt mod that will fix it, the one bolt method for those mills is a woeful design.
    Wisdom results from foolishness!
  7. #7
    Oct 2004
    Zenji, Can you supply a link?
Head to Table angel
Head to Table angel
