Originally Posted by
HimyKabibble
I cannot imagine any sub-$1000 machine being capable of cutting stainless at anything more than a positively glacial pace, if at all. Nor can I imagine a machine in that price range having the kind of accuracy or surface finish you'd probably want. It sure won't be anything even close to what you're getting right now with laser cutting. That is just not a realistic budget.
On your current parts, what portion of the cost is the laser cutting, and what part is the polishing? I'd be willing to bet the laser cutting is pretty cheap. If it's not, then you're dealing with the wrong shop. I'm making some laser-cut parts right now that are basically a 7.25" diameter circle with 36 "teeth" around the perimeter, a 1.5" center hole, four 45 degree x 5/16" bolt slots. 3/16" steel laser cut and zinc plated. They're costing me about $7 each, including shipping from PA to CA.
Regards,
Ray L.
Regards,
Ray L.
