x2 spindle motor replacement options ? - Page 12
Page 12 of 12 FirstFirst ... 29101112
Results 133 to 133 of 133
Thread: x2 spindle motor replacement options ?
  1. #133
    Jan 2018
    United Kingdom
    Default Re: x2 spindle motor replacement options ?
    I've decided I'm saving up for another mill (Chinese jobbie) to convert instead of the motor upgrade.
    My X2 has come along well so far. Belt unit, R8 spindle upgrade, solid column squeezed 155mm travel on the Y axis, 420oz/in steppers, homemade 350w 20Litre coolant system (overkill and powerful!!!)
    Gradually pushing up and gone up to 800mm/min with decent accuracy so far with a 6mm cutter but you can here the motor struggle a bit at times.
    The new mill I'm looking at is bigger than the Grizzly G0704.
    There's the Amadeal AMA30LV - R8 coming soon?
    The Warco WM18
    Only downside is these are gear driven
    Then there's the TOOLCO WM32B which is belted.
    All R8 out of stock atm and I'm impatient
    All 3 say they have a good 220mm travel on the Y axis which appeals to me.Much bigger than a X3 for a close price tag around £1450.
    I got slightly more Y travel than the X3 on my X2!
  2. #134
    Banned
    Apr 2019
    that's right
    direct swaps for the supply
    from what I've accumulated it will have a huge effect in torque and speed, so it ought to be great, or then again with my restricted hardware experience I may finish up expecting to supplant a cooked engine
    one thing that I've seen is a sensational change with giving it a 20-minute warm-up, the shaft is far less safe, its #@$ing hot yet free , I may attack the course and repack them sooner or later.
    https://crbtech.in/programmes/mechan...ning-programme
