New Machine Build Optimum BF20L CNC conversion using the Smooth Stepper - Page 39
Page 39 of 50 FirstFirst ... 293637383940414249 ... LastLast
Results 457 to 468 of 599
Thread: Optimum BF20L CNC conversion using the Smooth Stepper
  1. #457
    Gold Member FannBlade's Avatar
    Jun 2011
    Watched it earlier...one heck of first try! Very nice was that hard to program?
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  2. #458
    Registered Mad Welder's Avatar
    Jun 2011
    Ireland
    Thanks for the kind words and no to be honest it's a pretty simple GCode far easier than I first thought and even though it's my now current pulley at a 1:1 ratio the pulley is far from perfect.......I didn't quite align my Y axis to my A axis zero degrees and so one side of the teeth had the wrong relief chamfer. .....
    Eoin
  3. #459
    Jun 2011
    Ireland
    Hey guys anybody else having trouble uploading pics from Mobile android devices? I used to use my phone but just simply can't lately. ...
    Eoin
  4. #460
    May 2005
    Default For the last two to three days CNCZone has been screwed up.
    I believe they have those issues resolved now so if you spare still having issues something else might be going on.
    Quote Originally Posted by Mad Welder View Post
  5. #461
    Jun 2011
    Ireland
    Quote Originally Posted by wizard View Post
    well at least that answers why even uploading the pics in my last few posts were a hit and miss effort even from my PC......but still can't upload from my phone awhile ago..... hmmmmm...heaven forbid maybe my wife is correct "me and electronics just don't work....!"
    Eoin
  6. #462
    Jun 2011
    Ireland
    finally finished my motor guard/cover, and I've followed in the Tormach's setup with a hinged door....
    Attached Thumbnails Attached Thumbnails Optimum BF20L CNC conversion using the Smooth Stepper-2012-12-05-spindle-motor-door-png   Optimum BF20L CNC conversion using the Smooth Stepper-2012-12-03-21-14-30-png
    Eoin
  7. #463
    Oct 2012
    Your machine looks great. I'm just getting started on my G0704 and threads like yours give me something to aspire to.
  8. #464
    Jun 2011
    Ireland
    Quote Originally Posted by ChrisAttebery View Post
    Thank you very much, and I must admit that the three phase motor is a wee bit (well ok then maybe a little bit more than a wee bit) oversized for the BF20 and with the motor cover in place it looks like Alf or ET has landed.......
    Eoin
  9. #465
    Jun 2011
    Ireland
    Anybody else experiencing problems posting? I'm trying to post in another thread but keep getting a webpage stating .'Internal Server Error'
    Eoin
  10. #466
    Jun 2011
    Ireland
    I tried two different L-Belt pulley configurations to increase my spindle RPM’s...one was a 20 tooth pulley (for the spindle), and the other was a 32 tooth pulley (for the motor), however in the attached pic the teeth look ok but I must admit that my machines "nod" (as I've read it referred to), or where my Z axis is not trammed correctly or exactly perpendicular to the "Y" axis, and so one side of the tooth’s relief angle in all the pulleys is incorrect...
    Attached Thumbnails Attached Thumbnails Optimum BF20L CNC conversion using the Smooth Stepper-2012-12-13-23-28-14-png
    Eoin
  11. #467
    May 2005
    Default I'm not sure I follow.
    I'm assuming you made the pulleys yourself. Are you implying the nod is so bad as to have a significant impact on your pulleys? If so I find that hard to believe as such an extreme error or nod would show up pretty significantly in surfacing cuts.
    I'm wondering if you may have had a setup issue. Either that or I'm not following you at all as far as your description below.
  12. #468
    Registered Fastest1's Avatar
    Nov 2009
    Wizard, after thinking about the problem MW is having on the teeth and seeing his video. I would think 1 of 2 problems exist. If the spindle is not centered directly over the center of his arbor in the Y plane it would make the profile of the tooth more ramped on 1 side. The other hypothesis, I can't put into words yet.
    A lazy man does it twice.
