Newbie My X2 Mill Machine Planning and Build
Page 1 of 3 123 LastLast
Results 1 to 12 of 27
Thread: My X2 Mill Machine Planning and Build
    Nov 2009
    Default My X2 Mill Machine Planning and Build
    Hey all.
    I have had an itch that needs scratching for several years. I need a CNC Mill. Now that i am out of the Army and have a "real" job where I can actually have my own shop at home, I think its time to make my dream a reality. I make 1:1 aircraft cockpits and am a hobbyist gunsmith.
    My day job is as a draftsman/CAD Administrator with one of the big defense contractors in the aerospace industry, so I know CAD cold, however since we outsource almost all our designs for fab, I know almost nothing about milling.
    I keep seeing good things about the Sieg X2, and its ability to convert it to a good solid CNC mill for a fraction of the price of purpose built CNC mills. I do plan on purchasing mine from Harbor Freight on the next major holiday when they do a 25% off.
    For the actual CNC conversion, I am weighing which CNC Fusion kits to use, and am completely unfamiliar with what motor control hardware and motors to purchase.
    One of my big issues, is I would like to be able to maintain a manual control of the machine in addition to CNC for times when I just want to do a small part without drawing up a CAD model, CAMing it, programming it to Mach 3, etc.
    I also would like to eventually add an 4th axis on it for small projects such as making handguards for carbines, and such.
    I guess my big question is, "Where do I start?"
    Gold Member doorknob's Avatar
    Jan 2010
    There is a lot of info on this site that can help you. But there is so much info that it can be overwhelming.
    I bought an X2 with the HF 25% discount earlier this year, but I've been a bit of a slacker and haven't yet converted it. I am strongly considering getting the CNC Fusion conversion kit, however I have some concerns about their Z-axis design, and so I may end up "rolling my own" Z-axis, along the lines described here: The Home Machinist! • View topic - X2 Mini Mill Conversion begins
    I bought a belt-drive conversion kit (sold by one of the members on this site) and plan to make that change as the first step: Untitled Page
    As for motors and drivers, there are many choices, but one approach that seems to be favored is the 3-axis or 4-axis 381 oz. in. NEMA 23 kit including Gecko G540 and power supply from Keling (towards the bottom of the page): Page Title
    As far as retaining manual operation of the mill, the prevailing wisdom seems to be that using a "pendant" or MPG ("manual pulse generator") accessory to command the mill axes is a better solution than trying to actually manually move the axes through handwheels.
    Nov 2009
    Quote Originally Posted by doorknob View Post
    That is exactly my problem!
    Interesting! What is wrong with their Z-axis conversion?
    This is a pretty high priority on my mod list as well.
    Thanks for the link, I'll check that out.
    This shoulded be too hard, just a project box, a few switches, and figuring out how to connect it to the electronic controls.
    Thanks for the piointers, Doorknob!
    Dec 2009
    J,
    I'm not real sure about your intended purpose, the gunsmith comment makes me think that you would be wanting to potentially do some milling on harder steels. I will say that steel is definitely not where the X2 shines. I have had two of them now and in my experience steel is frustrating with these machines. Both in terms of controlling the vibration and chatter and in terms of the bite you can take per pass. That said they certainly are not incapable of cutting steel it just is not the machine's forte.
    The other area that is frustrating is the very limited useful Y axis envelope. The X isn't too horrible but the Y is really limiting I have found. There have been many this and that items I have worked on where that limit would be bumped into and add a lot of work to get around. If you anticipate a lot of slender or small work then it's not a huge deal. If you see working on items 4" or more in width then it may be more of an issue. Most of the milling vice options are going to limit that Y even more because of over-hang.
    As for handwheels. I'd forget about them. If you convert to ball screws then the dial markings are all wrong and the screws will have a tendency to back-drive. That is to allow force on the work piece to translate into motion of the screw. Not a good deal. The feel is all wrong too and the motors start to fight back even if they are not powered if you try to move the table quickly. There is no reason you can't mill a part without creating a program. You simply type the cut coordinates in and the feed-rate and it makes the pass. Move a little and repeat. You just have to keep the +/- thing straight as that's the fastest way to make a big oops that I have found, along with the 0.635 instead of 0.0635 thing, that will really ruin a day. Also having rapidly spinning entanglement dangers or knuckle rappers is not really desirable.
    The X2 is decent little machine and I've seen what it can do in aluminum and really it's quite impressive for the size of the machine once it's tuned up. For steel, if I were doing much of that, I would look for something larger. I would advise you to invest in some screw-machine length drills. Z clearance for drills can be a real bear if you are working on stuff other than plates and there is much added fixturing in the vise.
    I'm running a BF-20/G0704 size mill and I'll say that if you can at all swing it, then it really is a WORLD apart even as a manual mill. I can do things in steel that would have the X2 just squeal and die on. That said, there is no pre-finished kit for it so that may make it a no-go for you if you are looking for that. There are kits for the X3 machines though and it too will far out-do an X2. Bill Me Later and 6 months no interest can make that easier to do.
    Hey, it's easy to spend your money right? If you do go for the X2, some places that can give improvement are the gibs. Look to either make some nice brass ones or spend some time better fitting the existing ones. Also try to find a way to lock the adjustments on the gibs better. Mine vibrate loose CONSTANTLY. Snug gibs are necessary if you want to do good work. A belt drive is a big plus if you do CNC aluminum. The higher spindle speed means you have a fighting chance at the proper SFM in aluminum.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
    Jan 2010
    Quote Originally Posted by j.steensen View Post
    The CNC Fusion Z-axis conversion is asymmetric - it hangs the ballscrew off to the side of the column. Some users have reported loss of accuracy due to that design. In the article that I linked to, the author reworked the Z-axis design to center the ballscrew with the column, directly behind the milling head.
    Registered hoss2006's Avatar
    Apr 2006
    Yeah the Z design looks strangely familiar.
    Free plans here.
    Hossmachine_Cnc Conversion
    Hoss
    [URL]http://www.hossmachine.info[/URL] - Gosh, you've... really got some nice toys here. - Roy Batty -- [URL]http://www.g0704.com[/URL] - [url]http://www.bf20.com[/url] - [URL]http://www.g0602.com[/URL]
  7. #7
    Nov 2009
    Quote Originally Posted by photomankc View Post
    J,
    My main materials will be 7075-T6, 6065-T6, Brass, and Plastic. I'm a battle rifle guy, lots of ARs and such. I have no illusions about being able to work a barrel on this thing, but maybe fabricating sight mounts, etc.
    Makes sense. Most my work should be small sub-4" Y-axis parts.
    Roger. Understood!
    Worst case, I have a bear of a drill press. (My only real metal working tool in my shop currently.
    I would kill to be able to get the X3, but my son passed away at the beginning of the year, and I had just recently gotten out of the Army and still didn't have a job with health insurance so still got a long ways to go on medical bills. It would be about 2 years before I could get the X3, much less get it converted, as much as I would like one.
    Makes perfect sense, Door.
    Quote Originally Posted by hoss2006 View Post
    Free plans here.
    Hoss
    Hoss, I do believe that site is the mother lode. You really didn't want me to accomplish anything at work today. Thanks for the link!!!!
  8. #8
    Apr 2006
    That should keep you busy.
    flsteam did give a shout out as to the source of his Z axis design here.
    The Home Machinist! • View topic - X2 Mill CNC Conversion update
    the nyloc nut is a nice addition if you can cut threads in the mating part
    but I don't see any adjustment ability for the belt.
    If you don't get it perfect you'll get either binding or backlash, a slot makes life easier.
    Hoss
  9. #9
    Nov 2009
    What sort of tolerances should i expect to keep out of the X2 stock?
    After CNC conversion with ballscrews?
  10. #10
    Apr 2006
    What sort of tolerances should i expect to keep out of the X2 stock? +/- .015
    After CNC conversion with ballscrews? +/- .005
    generally speaking.
    Hoss
  11. #11
    Nov 2009
    Thanks Hoss!
  12. #12
    Apr 2006
    You can get those a little lower, use a DRO and mod the leadscrew nuts to take out some backlash on the stock machine
    or use oversize balls in the ballnuts and better bearings and couplers to get the backlash to near zero for the CNCed machine for example.
    Hoss
