Chester 20v and G0704 comparison - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Chester 20v and G0704 comparison
  1. #21
    Member arizonavideo's Avatar
    May 2008
    Default Re: Chester 20v and G0704 comparison
    For the RF-45 go ahead and run the 25mm. It will last longer.
    youtube videos of the G0704 under the name arizonavideo99
  2. #22
    Sep 2017
    United Kingdom
    Dear 109jb.
    Many thanks for yours and everybody's advice much appreciated.
    All I got to do is collate them all. work out the lengths.
    Then find a supplier as I live in North Scotland.
    Best wishes.
    Yours Mechan6
  3. #23
    Sep 2017
    United Kingdom
    Dear dazp1976,
    Thank you for your advice.
    As regards using the 1605DFU ballscrews.
    Not heard of that classification, but will look it up.
    I was thinking of using Two RK12 End support pre-loaded angular contact bearings on each end of the X Axis.
    As one end is motor driven other has a the handwheel.
    Thanks again, Best wishes.
    Mechan6
  4. #24
    Sep 2017
    United Kingdom
    Dear Stigoe,
    many thanks for the advice concerning the 2005 Ballascrew for the Z axis .
    My thoughts are inclining that way
    As I live in N Scotland , got to find a supplier to suit.
    Many thanks again.
    Yours Mechan6
  5. #25
    Sep 2017
    United Kingdom
    Dear shooter 123456.
    Many thanks for the advice regarding the 2005 and the Z axis ballscrew.
    And for taking the time to pull out the spec sheets, do the maths.
    As I live in N Scotland. Will now collate all advice, measure & draw up then find a supplier.
    Many thanks again.
    Yours
    Mechan6
  6. #26
    Dec 2012
    Norway
    Quote Originally Posted by Mechan6 View Post
    When you've found the needed lengths, find linearmotionbearings2008 on eBay. I can't remember his direct email address. He is the one most recommend for ballscrews. He can machine the screws to your drawings as well. He has both single and double nuts.
  7. #27
    Sep 2017
    United Kingdom
    Dear Stigoe,
    Many thanks for the supplier information.
    Will try them.
    Best wishes.
    Yours
    Mechan6
