Here are a few suggestions:
First; read up a bit on milling and general machining. It is not uncommon to make special purpose clamps, fixtures and tooling. This may or may not fullfill your needs.
Second; maybe it should have been first is catalogs. If you can get access to Travers, McMaster-Carr, MSC, Grand Tool Supply, Little Machine Shop and whom ever else you can dig up! Visit your local distributors and hope that they have a reasonable attitude. And finally go to the model engineering shows like NAMES, Cabin Fever and what ever is local.
The reality is that your tooling expense will quickly out strip the cost of the machine itself. If you got time on your hands it would pay to make the stuff you need yourself. Especially for the smaller machines where finding mass produced tooling is a little harder. Larger machines have whole industries built around them so for example it is hard to beat the clamps available for a bridgeport.
Other things to consider are figuring out what your slot size is and getting yourself an assortment of cap screws, Nuts and hardwashers. With a bit of careful planning you should be able to cover much of your clamping needs with such bolts and a few home built clamps. Just make sure you cover yourself with designs that have the required strength. Shouldn,t be a big deal no a mill this size but the las thing your want are parts slipping arround while your CNC mill is happily running away.
Dave
