NEMA 34 steppers will be fine. I run my mill with a 27kg 6" vice on one end of the table sometimes. When machining at the other end that puts quite a bit of friction into the system - absolutely no problems even at rapid, and that is on my low power system (39VDC @ 6A/motor).
