Hoss's G0704 - Page 145
Page 145 of 571 FirstFirst ... 4595135142143144145146147148155195245 ... LastLast
Results 1,729 to 1,740 of 6847
Thread: Hoss's G0704
  1. #1729
    Gold Member hoss2006's Avatar
    Apr 2006
    Another gutted Philips USB PC game controller, $5 on Ebay.
    Gives 16 button capability with 4 axis joysticks.
    Keygrabber to assign the buttons works great as usual.
    Projects 2
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #1730
    Apr 2009
    Very cool control panel!! I just started using keygrabber last night works great.
    I was watching some of your videos on youtube and I was wondering what kind of air cylinder are you using on your power drawbar? I am toying with the idea of re doing my current spindle and would love a auto drawbar like that.
    Thanks,
    Eric
  3. #1731
    Apr 2006
    It's a 3 stage air cylinder that I made myself.
    It will put out about 2100 lbs of force at 100 psi.
    Check Ebay for multi-stage Fabco air cylinders, you may be able to snag one for less than $50.
    This page will tell you what the part #'s mean.
    Catalogue - Master Catalog - FABCO-AIR - (Version JPG) - page 109
    On a similar note, I just snagged a steal on a Fabco Air Booster on Ebay that
    could give me nearly 6000 lbs of force from my air cylinder, if I was crazy enough to try.
    3000 will do.
    Hoss
  4. #1732
    Oct 2008
    Hoss, do you have a picture of one. My searches came up nil, mainly volume boosters. The pressure intensifiers didn't yeild too much either.
    Richard
    Quote Originally Posted by hoss2006 View Post
    3000 will do.
    Hoss
    RF-45 CNC Mill with 10 Position ATC, GH-1340 Lathe, Sharp 10x54 TMV-K Mill, Leblond 19x78 Lathe, 16" Cincinnati Shaper, CRP4848 Router, 60x60 CNC Plasma Cutter.
  5. #1733
    Apr 2006
    This is the one I got, it's just missing the air valve which I already have.
    FABCO-AIR AIR HYDRAULIC BOOSTER #B5003, 500PSI | eBay
    The construction is similar to my air cylinder but much bigger and ported differently.
    I was going to make a bootstrap compressor but not now.
    Here's a homemade amplifier from scrounged parts, (not the first pic, that's a commercial one)
    Home made air pressure amplifier - S-10 Forum
    Hoss
  6. #1734
    Aug 2007
    Default safety first
    Hoss, does your estop circuit also dump air pressure?
  7. #1735
    Apr 2006
    If I had a local scuba shop that could refill tanks, I would have used one with a regulator
    to supply the air cylinder with a couple hundred psi.
    A single 3.5 -4 inch air cylinder would do the trick then.
    Not much scuba interest here in the mountain state though.
    Hoss
  8. #1736
    Apr 2006
    Quote Originally Posted by Hans_G View Post
    Sounds like a good idea to add to the console setup, I'll make a note of it, thanks.
    Hoss
  9. #1737
    Apr 2006
    Here you go, after a little googling, a scuba tank for powering air tools.
    SCUBA Air Tools
    If my math is correct, in thory, I could get almost 10,000 cycles from the scuba tank.
    probably not, seems high.
    Hoss
    On further review, maybe about 3500 strokes at 200 psi, still that could last a year ish per fill.
  10. #1738
    Jun 2011
    If you went with an Al tank you'd get slightly less that 80Cuft, if you went with steel you can get 120Cuft relatively commonly and many shops will "overfill" a steel tank.
    In practice you you'd only run them down to ~500psi before refilling, scuba stores will sometimes insist on a vis if the tank is drained.
  11. #1739
    Gold Member Connor's Avatar
    Aug 2010
    Hoss
    That's a good idea.. I have 2 steel tanks (2200psi rating) I could use.. though I think they need to be inspected and have a hydro test on them.. I have a dive shop right down the road. I hate having to listen to my Air compressor.. It's so DAMN loud. How much stroke is needed on the air cylinder? What about a solid or hydraulic vs pneumatics?
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
  12. #1740
    Apr 2006
    I mentioned using air/hydraulic a long time ago, the hydraulic hose and cylinder are sitting in a box.
    I may try them with the air booster since it can use hydraulics too.
    Trying this first.
    Hoss
Hoss's G0704
Hoss's G0704
